lowering question
Trevor
lowering question
Postby Trevor » Sat May 19, 2012 12:32 am
Anyone know where I could get the stuff to lower the rearend of a '71 chevy c20 with leaf spring? Emailed Summit and Belteck and they dont offer anything. Any suggestions?
Thanks
Trevor
Stitches custom upholstery
207-7829
www.hubgarage.com/mygarage/redbeard
Re: lowering question
Postby Larry Jr. » Sat May 19, 2012 8:33 am
i know a guy pretty well that can de-arch those springs for you....
bring the by the spring shop trevor, and i will fix ya up
novahaulic
Postby novahaulic » Sat May 19, 2012 5:09 pm
They say that guy at fleetpride can do it. I have heard he is a little shady so be careful when dealing with him. I think his name is Gary or something like that. Little scrawny guy.
dwesterhouse
Postby dwesterhouse » Mon May 28, 2012 1:13 pm
u could readjust the mounts a little further out and the remount them and that would lower it
Postby Larry Jr. » Mon May 28, 2012 10:14 pm
dwesterhouse wrote:u could readjust the mounts a little further out and the remount them and that would lower it
or you could do it the proper way and de-arch the springs.
novice
Postby novice » Mon May 28, 2012 10:19 pm
can some of the leafs be removed?
James Kelley
Postby James Kelley » Tue May 29, 2012 3:41 pm
Torch it !!!!!!! :D
Postby 55promod » Tue May 29, 2012 3:57 pm
Have __________(you fill in the blank) sit in it. :o :twisted:
James Kelley
Postby James Kelley » Tue May 29, 2012 4:05 pm
55promod wrote:Have __________(you fill in the blank) sit in it. :o :twisted:
MITCH!!!!!!!!!!!!!!!!!!!!!!!!! :D :D :D :D :D Sorry Old buddy but I had to
terryl
Postby terryl » Thu May 31, 2012 11:44 am
I have a 86 chevy short wide bed. If you move the rear end on top of the spring it will drop the rear around 4 inches. With that i had to c notch my frame so the axle had some travel. The other good thing is you can add a slide o link to stop the wheel hop. I used one for a S10 had to burr grind the holes to match the u bolts. The front end has 2 inch drop spindles plus we cut some of the coil spring off too. my truck has apretty good stance now.
Users browsing this forum: No registered users and 3 guests
