Shootout classes....?
GST
Postby GST » Sun Sep 30, 2012 3:15 pm
Next year, is there a possibility of adding an outlaw 8.5 class to the line-up at shootouts?
mr_biscuitz408
Re: Shootout classes....?
Postby mr_biscuitz408 » Sun Sep 30, 2012 7:31 pm
Do what?
GST
Postby GST » Sun Sep 30, 2012 9:32 pm
mr_biscuitz408 wrote:Do what?
Well, no ladder bars and no turbos are allowed in mean street. So i figure you add a class that allows either of those small tire cars (26x8.5). Make as little of rules in the class as possssible since they dont get followed as is in a couple of classes. Maybe some of the mean street guys would step up and try it out. Same thing as the "small tire in the backwoods" race just make a class out of it.
Steve88
Postby Steve88 » Mon Oct 01, 2012 11:33 am
This sounds like a good idea. There are a good number of cars locally that are just outside the rules of some of the regualr shootout classes for one reason or another so having a small tire class that is pretty much run what you brung on a small tire sounds interesting and would help the car count and be a good show for the spectators also.
2bqwik
Postby 2bqwik » Wed Oct 17, 2012 6:51 pm
The VAMP series is going away next year Dave Hight has decided to take a break so we decided to start a group called MW8.5RA(Midwest 8.5 Racers Association) to continue on with our 8.5 class we have going up here in Kansas City area. We kept it a plate class but added some NA and boosted combo rules with some basic weights. Pretty open rules but some limits to try and keep it from being ridiculous. Anyways you can check us out on Facebook and we have a section on http://www.purposebuilt.org. We are in talks with all the tracks and hoping to grow this type of racing in the midwest. I've included the rules below if you wanna check out. Thanks for looking! Chris
2013 MW8.5RA Rules
MW8.5RA
"Crazy 8's"
FORMAT
This is an 1/8th mile heads-up class run on a .400 pro tree with a pro ladder. MW8.5RA is a qualified quick 16 field. We will also run a second chance race or test and tune if more than 16 cars. This will allow non qualifiers to compete for additional purse or more track time. If more than 32 cars we will do 2-16 car field run on pro ladder.
Class is designed for rear wheel drive small block and big block vehicles with single stage plate systems, boosted small blocks and naturally aspirated small/big blocks.
SAFETY
All NHRA/IHRA and local track safety rules apply for driver and car.
TIRES
26x8.5 slicks- May have Mickey Thompson(3052) or Hoosier (18115C11) only.
BODY
The car must retain its original appearance, profiles, and dimensions. Factory roof and quarter panels must be used. Aftermarket fiberglass and/or carbon fiber replacement panels are limited to hood, front fenders(no one piece front ends), doors, deck-lids, and bumpers only. All front ends must be of factory dimensions and cannot be stretched. Aftermarket wings and spoilers are permitted. Complete stock appearing front and rear bumpers are required. A hood must be used. Forward facing hood scoops/turbo or supercharger inlets are permitted. Beam trippers, extenders prohibited. Must have working headlights and taillights. Any charging system legal.
INTERIOR
Factory appearing dash, door panels, and driver seat in stock location required. Carpet may be omitted for safety. Factory floor pan on driver and passenger side required. Must have factory transmission tunnel(no removable transmission tunnel) Aftermarket steering column permitted.
WINDSHIELD/WINDOWS
OEM glass or lexan windows are permitted.
CHASSIS
Complete stock chassis and frame rails must be retained from shock tower to behind the rear wheel opening. Back halved cars are not permitted. Front core support may be modified or removed. Aftermarket bolt-on replacement front K-members/sub frames are allowed. Front shocks must be in factory location. Factory wheelbase must be maintained.
EXHAUST
Mufflers or inserts are required on all cars except for turbo cars. Exhaust may exit underneath car or out the front fenders but must not affect timing or staging beams.
SUSPENSION
Stock style, ladder bar or torque arm suspension cars only. Aftermarket four links are prohibited on all cars. Aftermarket replacement components such as: front control arms, rear control arms, front coil over shocks, and rear coil over shocks are permitted. Rear suspension may be moved to accommodate tire clearance and does not need to be mounted in stock location. Wheelie bars prohibited.
ELECTRONICS
Any ignition or efi system on all combos. Boost controller legal. N2O controllers legal. No Davis traction control, BS3 Torque management, Fast Intelligent control or other similar products. Data logging allowed.
TRANSMISSION – any automatic or manual transmission allowed
FUEL – Any race gasoline permitted . Alcohol only allowed with naturally aspirated motors. E85 legal for all combos. E98 only if non-intercooled.
WEIGHTS
4CYL 2150(n20 allowed on turbo)
6CYL 2800(single power adder only)
SBNA 2550
BBNA 3000
SBN20 3000
BBN20 3200
SB BOOST 3200
**Deduct 100 for factory valve angle heads(20*Ford, 23*Chevy, 15*LS, 18*Mopar) on (SBNA, BBNA, SBN20) ONLY
SMALL BLOCKS—N2O
Any single carb or throttle body allowed.
Aftermarket cast iron/aluminum blocks ok(no billet), any cast heads ok(no billet).
No sheet metal intakes allowed, only cast, commercially available.
Allowed any single stage production plate system including crossbar and diffuser style. Must have one fuel and one nitrous solenoid max on carb applications. EFI allowed 2 nozzles for N20. Foggers can be installed on car but must be capped before tech.
May have an inline single solenoid purge which must exit above the hood.
-6an line MAX from bottle to N20 solenoid with 12" MINIMUM of -4an off of N20 solenoid. Nano or other pressure regulating systems are allowed. Only a single N20 bottle may be mounted.
Nitrous controllers allowed.
Small blocks with more than 440 ci will run under big block rules.
All Buick, Oldsmobile, Pontiac, Cadillac, AMC will run under small block rules w/max 500ci.
BIG BLOCKS-N20
MAX deck height(10.2 Chevy, 10.3 Ford, 10.7 Mopar) 598 MAX CI and conventional heads only. Aftermarket cast iron/aluminum blocks ok(no billet).
BOOSTED(SMALL BLOCK ONLY)(No N20 any boosted combo except 4cyl)
Aftermarket cast iron/aluminum blocks ok (no billet), any cast heads ok (no billet).
Single carb or throttle body allowed.
No sheet metal intakes allowed, only cast commercially available. Custom elbow ok
Any race fuel or E85 (E98 non intercooled only, no alcohol).
All blowers and turbos are to be UNMODIFIED (NO AFTERMARKET CHANGES MUST BE FACTORY PRODUCED).
#1 TURBOS mid frame 88mm MAX( mid frame Y2K or GT47-88 etc.) unmodified.
No billet wheels, no large frame turbos or reducers.
Any intercooler allowed.
BLOWERS F1C or equivalent MAX Unmodified.
Gear drive/forward facing blowers legal.
#2 TURBOS large frame 88mm MAX(X275 88mm etc), Twin 67's max Unmodified.
Billet wheel legal, large frame legal, no reducers.
Must be intercooled in front of firewall.
Meth injection legal on air to air or non intercooled combos.
BLOWERS F1R or equivalent MAX Unmodified.
SMALL BLOCK-NA
Must be naturally aspirated.
Aftermarket cast iron/aluminum blocks ok (no billet).
No CI/Head limit.
Sheet metal intakes allowed.
Multiple carb/throttle body legal.
Alcohol allowed.
BIG BLOCKS–NA
Any BB single carb or throttle body, aftermarket cast iron/aluminum blocks ok (no billet). (Max 10.2 deck Chevy, 10.3 Ford, 10.7 for Mopar).
632 MAX CI.
Any heads.
No sheet metal intakes, only cast, commercially available.
Alcohol allowed.
Car tech will be done randomly at races. If found in violation of rules(that are considered to gain an unfair advantage) a one race suspension will be put in place. 2nd offense removal from series for rest of season.
PARITY – OFFICIALS MAY IMPOSE RESTRICTIONS TO ANY PARTICIPANT DISPLAYING ADVANTAGEOUS PERFORMANCE.
LEGALITY OF ANY CAR IS THE DECISION OF THE RACE/TECH DIRECTOR.
WWW.MW85RA.ORG
Say yes to 8.5's :)
Users browsing this forum: Yahoo [Bot] and 2 guests
