Power glide ???
Power glide ???
Can the tail shaft be pulled while in the car??? and if so is it easy ? Mines leaking
Re: Power glide ???
James, yes you can pull the tail housing off while in the car. The trans mount is bolted to the tail housing so you will have to find a way to support the rest of the transmission.
I volunteer Mitch or Larry to come over and help. Just let them know when to be there.
Re: Power glide ???
55promod wrote:James, yes you can pull the tail housing off while in the car. The trans mount is bolted to the tail housing so you will have to find a way to support the rest of the transmission.
Thanks Keith I will call Larry the last time mitch offered some help?????????? Well Im still waiting on the calls
Users browsing this forum: No registered users and 3 guests
