Who can put an SFI bell on an AOD?
good'ole302
Postby good'ole302 » Wed Nov 20, 2013 4:54 pm
The bellhousing on a built AOD I have is cracked 1/2 of the way around or so. Had it sold, went to pull from running car...found that. Only real options I've seen are replacing the case (~$500) or finding someone to put a JW ultra-bell on it (bellhousing is ~$380, ? on labor). I like the idea of the bell housing replacement the best as it adds value, vs just being out the $ on a stock case.
Anyone around that can do the bell install? Other ideas?
Thanks!!
Mike
'95 Mustang GT-408
'95 Mustang GT #2- DD "The Rattletrap"
nck
Re: Who can put an SFI bell on an AOD?
Postby nck » Thu Nov 21, 2013 5:42 pm
Call C&R Racing transmission 4177362191
JOHN RADER
NO COAST KUSTOMS
417-257-5377
bad355_67camaro
Postby bad355_67camaro » Sat Dec 14, 2013 11:58 pm
^Yup, roy should be able to get you taken care of no problem.
good'ole302
Postby good'ole302 » Sun Jan 12, 2014 3:19 pm
Thanks guys. I am pretty sure I called C&R, and they said no...but I'll call again. It's a simple job, so simple that I have just about finished it in my shop.
Sometimes it's the simple things that get ya...final step of torquing the BH down with red loctite and orings...one of the pump bolt holes stripped out with less than 20ftlb. I swear this transmission has determined that A: it's done working for me, and B: it ain't gonna be sold to anyone else. :great
'95 Mustang GT-408
good'ole302
Postby good'ole302 » Mon Jan 27, 2014 3:07 pm
Thanks for the advice guys! Roy @ C&R was awesome and got me fixed right up!
Anyone that needs a transmission done from a top-notch guy...talk to Roy at C&R!
'95 Mustang GT-408
Users browsing this forum: Baidu [Spider] and 1 guest
