Narrowed Ford 9 inch
Rzrrider1
Postby Rzrrider1 » Mon Feb 01, 2016 1:23 pm
Who in the area narrows Ford 9 inch rearends ?
novice
Re: Narrowed Ford 9 inch
Postby novice » Wed Feb 03, 2016 8:46 pm
can't believe someone hasn't replied to this, but TYDO might do it, he is in seymour, show-me speed might do it, if not they might know who can, and if you want to drive a little, look on the mo-kan website under tech talk, about 15-20 rows down (rear end narrowing), there is a guy in kansas, named snyder, I think, who says he can do it, and last but maybe closer, in the for sale section (orp), jerry21ace has a 58" wide housing with axles, in case you have not seen his add.
Rzrrider1
Postby Rzrrider1 » Wed Feb 03, 2016 9:43 pm
Thanks for the info. I've been out of racing for about 15 years so I have no clue who does anything anymore. Apparently not many guys doing any work like that anymore. I seen the post on the 58" but I'm needing to be at about 43" total width and I already have a housing.
novice
Postby novice » Thu Feb 04, 2016 8:35 pm
the guy that did mine was doug crumbliss (doug crumbliss racing), he was just across the line in kansas when he did mine but I think he might have moved. he is probably close to the four corners area somewhere, just google him up.
midmoracer
Postby midmoracer » Tue May 03, 2016 4:25 pm
Midwest chassis works in Columbia mo can narrow rearends.
