FS: sbc and glide
383rx7
FS: sbc and glide
Postby 383rx7 » Tue Feb 09, 2010 3:11 pm
Hey have a sbc with low miles probably less than 1000 street miles and less than 10 quarter passes. Asking $3200
ohio 4340 3.75 crank, Ohio 6in h-beam rods arp bolts, JE flat top .40 gasport pistons around 10.8-11.1, comp cams flat tappet cam 59x lift, Comp lifters, Moroso 7qt pan and hv pump
Pro comp CNC'd heads, 2.02 intake 1.60 exhaust, dual springs retainers spec'd for cam, scorpion 1.6/1.5 rocker, stud girdle, pushrods, aluminum timing cover, balancer and flex plate
M&M basic racing glide $800
turbo input shaft, 8 clutch direct drum, stock 1.76 planitary, pro tree brake
Transmission speciltys convertor $350
stalled around 4500 behind above motor
383rx7
Re: FS: sbc and glide
Postby 383rx7 » Sun Feb 28, 2010 12:00 pm
sold
Users browsing this forum: MSNbot Media and 1 guest
