1972 datsun 240z 355 alcohol for sale or trade 417-280-0808
racerfreddy
Postby racerfreddy » Sat Apr 10, 2010 7:48 am
I traded for the car this week and cannot fit in it. I am 6'3" 290 if you are over 6' 220 dont trade for this car. I will use the description from the guy i traded with. New Pro Built Tube Chassis Super-Pro/Super-Gas/Super Comp car powered by a SBC 355 Roller motor on Methanol.
We just spent 10 months having this car built. No expense was spared. We have over $30,000. invested in this car. There is NO JUNK here and there is nothing to apologize about on this car. The car has 18-passes on it now. Friday night we made two passes and ran 6.55 and 6.54 in the 8th @105. Thats leaving at 3600 and shifting at 5500. There is LOTS of power and speed left. The car has run 5.94 with different set up. The car hooks hard, goes straight every time.
Here are a few details about the car;
1972 240-Z
New and Professionally Built by Caveman Racing
New Professional Built Mild Steal Tube Chassis by Caveman Racing
New NHRA Certification to 8.50 on 8/09
The shell is metal except New Pro Mod Carbon Fiber Scoop
The Hood and Doors are removable
Wgt 2180-lb,1130-lb Frt,1365-lbs Rr,Good Wgt distribution
The engine was moved back 9" as allowed by NHRA
New SFI NHRA required items & current dates to pass Tech
The car is a Ladder bar car with Koni adj. Coil Overs
The 4-Gal. RCI fuel cell is located in front
New Belt Drive CSR Fuel pump and Alky Regulator
New Push Lock Fuel lines with AN fittings
New Scirraco Aluminum Radiator w/Fan
New SBC 355 Roller Motor, Dart Pro 1 Aluminum heads all Ported & Gasket matched, 64cc Chamber, 227cc Intake Runner w/2.08 & 1.60 Valves w/Titanium keepers
New ARP Head & Main Bolts
New Billet Aluminum Valve Covers
New 950 Avanti built Holley Methanol Carb.
New Victor Jr. Air Gap w/2" spacer
New MSD Distributor w/Brass gear
New MSD 7AL-2 Ign. Box
New Accel 8mm. plug wires
New Hooker Super Comp Coated Headers w/turn outs
New Lunati Roller Cam, Roller Lifters
New Crane Roller Rockers and Stud Girdles
New Eagle Rotate Assem. 13.5:1 JE Forg Pistons,Speed Pro Rings
New 5500 TCI Conv. will handle (1,200 HP)
New Glide with Pro Brake and TCI 1.76 Vasco Planet gear set
New 9" Ford w/456 Richmond's, Moser 35 spline axles & Full spool
New Disc Brakes on 4 corners & New Diamond Cut Drilled Rotors
New Brake Plumbing and New Wilwood Brake Pedal and Resavor
New GM Chrome one wire 100 amp. alternator
New Custom Fabricated Battery box located in the rear
New Battery hidden by Aluminum cover with Zeus fasteners
New 70" adjustable Whillie Bars
New Custom Fabricated Aluminum Interior
New Removable Transmission Tunnel with Zeus fasteners
New Kirkey Economy Drag Seat
New RCI 5-point Dragster Belts
New Wiring Front to Back
New B&M Shifter w/Line Lock button & Custom made Pod
New B&M Role Control
New Shifnoid Electric Shifter
Mega 400 Delay Box
New Autometer Gauges;
New 5" Monster Tach w/Shift Light
New 2-5/8" Mechanical Oil Pressure Gauge
New 2-5/8" Elec. Temp. Gauge
New 2-5/8" Elec. Volt Gauge
New MSD 7AL-2 Ignition Box
New MSD RPM Activated Switch
New MSD 3-Step
New MSD RPM Module switch selecter
New ProComp 65,000 Volt Coil
New Moroso 6 Switch Panel w/Breakers
New Ocsilating fan (keep cool)
New Custom Dome Light w/25' ext Cord Great at Night
New Billet made Aluminum Helmet hanger
New Billet made Aluminum Steering wheel hanger
New Fire Extingisher
New TCI Trans Brake Button
New Moroso ON/OFF switch with Custom Warning Light
New Posi & Neg Brass Battery terminal hides in Factory Gas lid.
Weld Drag Light Racing Wheels
Goodyear 24x3.5x15 Front Runners
Hoosier 29.5x12.5x15 Rear Slicks
New Paint. (race quality, not show)
New Nomar Lexan Glass all Windows.
Users browsing this forum: Google [Bot] and 6 guests
