1968 Turbo Camaro, PS/OL10.5, 25.2 cert
clad1969
Postby clad1969 » Sat May 15, 2010 9:35 am
25.2 chassis built professionally built by Holzman racecars in Wichita, Kansas. Nhra and Ihra certified to 6.00 565 BBC built with parts from Shafiroff Racing and Reher Morrison Turbo People Custom camshaft 106 mm Precision Turbo Youngs Performance 2 stage boost controller Accu Fab 90 mm Throttle Body and Alum Sheet metal hat Indy waste gate Godzilla blow off valve PT 3000 Air to water intercooler MSD 7531 traction control ignition Accel DFI Gen 7 fuel injection with wide band O2 Accel DFI on board data logger 160 lb fuel injectors Auto meter gauges 16 Volt battery Weldon belt drive fuel pump system Trans Specialty Power Glide ( Straight cut 1.80 ratio, Nasa Input Shaft, etc ) 10 in Chance Pro Mod Bolt together converter Mid plate and motor plate 9" Strange rearend Double adjustable ladder bars Anti roll bar Strange driveshaft Strange double adjustable rear shocks Strange single adjustable front shocks 84" chromoly wheelie bars Stroud spring launcher parachute Fiberglass deck lid Fiberglass doors Fiberglass hood Fiberglass Front Clip ( removable ) Lexan Windows Alum Wing Wilwood disc brakes all 4 wheels Monocue wheels Painless wiring switch panel Kirkey alum seat Stroud window net 5 way seat belt harness Front mounted fuel cell Grant removable steering wheel Removable tunnel B+M shifter with shiftnoid Car has original dash with VIN number still installed Car has offroad Kansas title Car will except 17 x 33’s, currently has 10.5W x 33’s on it, the way I raced it. Car weighs #2825 wet with no driver, 8 passes on motor and tranny since freshened. Ran 1.16 60 ft, 4.70’s 1/8 mile, 7.30’s @ 193 mph with rich tune up on 10.5w’s, I personally think the car easily has another 2-3 tenths and 7-9 mph in it with more tuning. Very nice car , Asking $55,000 Firm Turn key or $32,000 minus motor and transimission ( All turbo system components included). ( I have $63,000 in parts alone on this car ) Serious inquiries only please. For any questions or more pics, email me at clad1969@yahoo.com
You do not have the required permissions to view the files attached to this post.
Users browsing this forum: Yahoo [Bot] and 1 guest
