complete SBC forsale Cheap! -PICS-
iroc383kid
Postby iroc383kid » Sun Jun 06, 2010 10:25 pm
NEEDS TO GO !!! Running fine when pulled (just going to a different engine set up for my car) Everything but NO belts,plug wires,carb
SBC 355 with about 3k on re-fresh
bored .030 with flat tops
recondition stock rods
Stock crank turned 10/10
.882 heads with 2.02/1.60 valves,screw in studs and guide plates
Comp Magnum 1.52 roller rockers with polly locks
Comp 292/510 hyd. flat tappet cam with +.100 harden pushrods
Double roller timing chain
Holley single plan intake
MSD Billet dist and coil --- p/n is 8360 on dist.
Chrome timing cover and valve covers
Comes with all pulleys,alt.starter,mounts,brackets etc.
$500 FIRM takes its Need it out of my garage to make room for other stuff and will NOT take any less so dont ask me to! Everything is best to my knowledge/as is. Also traced back to the orgin. owner of the car that this engine was in (and he is a straight shooter and never gave me any reason to doubt him at all!!) Engine ran good while in my car, had a nice thump but never took it to the track nor ran it hard (pulled it from the car so I could work on other areas of the car)
PM me on the site or E-mail me at greendaynofxpunk@yhoo.com
located in Springfield might be able to deliver if you live in Springfield only!
thanks,
Brandon
'06 Silverado -low and slow-
iroc383kid
Re: complete SBC forsale Cheap! -PICS-
Postby iroc383kid » Sun Jun 06, 2010 10:45 pm
Sorry forgot to say 1 head needs another helicoil put back in (it pulled out just abit when I took the headers off during pull) but cheap easy fix none the less (little dirty cause I had a stupid plastic tube for my oil gauge leaked) MSD dist DOES come with it just removed for removal of engine from the car. TRANS NOT INCLUDED but wooden stand is :D
thanks again
Brandon
RUN-NE1
Postby RUN-NE1 » Mon Jun 07, 2010 8:48 am
Are you coming to KC any time soon? Or anywhere near? I dont think I will be down there for a while. I could use this now.
thanks 816 679-2116
Just a small block EFI pump gas plate nitrous street car.
MW8.5RA/Vamp 8.5 car.
Silver 1991 Mustang GT
RUN-NE1
Postby RUN-NE1 » Mon Jun 07, 2010 9:00 am
iroc383kid
Postby iroc383kid » Mon Jun 07, 2010 10:05 am
From what i was told it should be the first one listed in the link.
iroc383kid
Postby iroc383kid » Wed Jun 09, 2010 9:03 pm
Sale pending!
R72Toy
Postby R72Toy » Thu Jun 10, 2010 10:06 am
would be interested if you have not sold cash deal if you would deliver to my shop in springfield give me a call 417-299-3926 Thanks
Just Jim
Postby Just Jim » Thu Jun 10, 2010 10:21 pm
that engine ran great when i had the car, no serious problems, ran like a champ.....talk to larry jr he knows a little about it..............good luck on the sale.... :thumbsup:
slightly burned out, but still smokin'......
