Register    Login    Forum    Search    Terms of Service
Board index » Classifieds » For Sale
Post new topic Reply to topic  [ 4 posts ]
 Post subject: 1979 MUSTANG COBRA 351W swap street/strip car $5,200
 Post Posted: Thu Jul 29, 2010 8:42 pm
I'm selling my '79 Mustang Cobra Street/Strip car. The body is straight and it has very little rust. I've owned this car 17 years and in 1998, I swapped in a built 351W, c4 trans with 2,800 rpm stall converter. It has been garage kept sense then and has received many other upgrades. This car has 129,000 mile on it but has less than 2,000 miles on the new engine, trans, and other new parts! I built this car with the intentions of bringing to the track to play, but I haven't the means(trailer) to bring her out with out the help of friends. It has been a good project for me and she has turned into a really strong running car but it's time to let her go. I'm guessing horse power/torque to be about 425/450(on my butt dyno) at the crank. I have over $10,000 invested(you know how that is) but I'm asking $5,200 cash. No trades please. Feel free to ask me any questions about the car and/or make me a reasonable offer. Thanks!
New Parts Include:
-1974 351W block bored 30 over
-1977 Stock rods and crank turned 10/10, balanced
-Flat top hypereutectic pistons 10.5:1 compression
-Meling Stock volume oil pump and 6 quart fox body oil pan
-Double roller timing set
-Comp Cams Extreme Energy flat tappet cam 541/544 lift 284 duration 110 lobe separation
-World Products Windsor jr heads 1.94/1.60 valves 180 runners 58cc chambers
-Crane Energizer 1.6 aluminum roller rockers
-Comp Cams hardened push rods and guide plates
-Edelbrock Victor jr single plane intake and 1" alum carb spacer
-Holley 670cfm Street Avenger carburetor with vacuum secondaries
-K/N 14"x6" air filter
-Stock water pump with Moroso electric drive
-Aluminum radiator with 16" electric fan
-Hooker Super Comp 1.75" long tube headers
-2.5" off-road H-pipe
-Thrush Mufflers dumped in front of the rear end
-Moroso solid motor mounts
-C4 auto trans with Manual valve body, speedo gear and 2,800rpm stall converter
-Rebuilt stock drive shaft with safety loop
-Rebuilt stock 8.8" rear end with 4.10:1 gears
-BBK Gripps lower control arms
-Lakewood adjustable uppers
-Jegs sub-frame connectors
-Ford double hump trans cross member
-Eibach front drag springs
-Holley blue pump electric fuel pump with 3/8" line
-RCI 12 gallon fuel cell
-2 trunk mounted batteries
-High torque mini starter
-Crane Hi-6 Ignition and Nology Pro Fire coil
-RCI race seats with black covers and 5 point harness
-Hurst Quarter Stick and Turbo Action Command Center with starter button
-Autometer Sport-Comp tac and Proform shift light
-Weld Draglite wheels 15x6 front, 15x8 back
-New stock brakes and Crane Cams vacuum can
And much more...ImageImageImageImage
 Profile E-mail
 Post subject: Re: 1979 MUSTANG COBRA 351W swap street/strip car $5,750
 Post Posted: Thu Jul 29, 2010 10:51 pm
nice looking stang............
_________________
slightly burned out, but still smokin'......on the road to success there are no shortcuts!!
 Profile E-mail
 Post Posted: Fri Jul 30, 2010 6:19 pm
Thanks Jim, You know anybody that might be interested?
 Profile E-mail
 Post Posted: Mon Aug 02, 2010 9:09 pm
Come on yal, someone ask me a question and/or shoot me an offer. I know your all looking, now talk to me.
 Profile E-mail
