1981 Firebird drag car
schafracer
Postby schafracer » Sun Aug 01, 2010 5:32 pm
Great drag car in excellent condition. Stays in garage. No rust. Has lots more room for upgrades. Best time so far with mild built motor 8.80's in 1000ft, 1.4-1.5 60ft times. Has lots of goodies-all autolight ultra silver gauges and monster tack,7al-3 msd box,msd resister for box,lots of extra switches,set up for nitroius(has guages, purge switch and dedicated fuel system),2-1/2" stainless steal fuel line'2-Holley blue fuel pumps w/fuel filters, gas tank has built in sump, 10-point roll cage,frame connectors and frame has been reenforced,1 peice fiberglass frontend,fiberglass doors, 6" fiberglass cowl hood,griffin alluminum radiator,line lock,convo pro wheels,street machine lift bars,drive line loop,front trick springs, 90-10 front shocks,automatic electric fan w/shroud, quarter stick pistal grip shifter,2-racing seats w/harness,10-bolt POSI rear w/4.56 gear,rear battery box w/ultima red top,aluminum dash,Goodyear slicks-29x11.0x15.
TRANNY-is a C&R racing tranny with some custom stuff. Drums been lightened and others been lightened. Bell is a uni-bell. Stall converter is a 9" 3500-4500(flashes to 4200+,PUMP HAS BEEN DONE FOR MORE FLOW. Has more goodies. Has about 50 passes.
MOTOR- 396 chevy BIG BLOCK .30 over 402 CUBIC INCHES. motor has been balanced and blue printed,cam has been degreed, manes been studded, all good fasteners,BLOCK is a 1968,12.5 -13.5 compression
PISTONS(P#L2887) TRW FORGED/508 DOMES
CAM(P#01351)CROWLER LIFT IN.601 EX.619 DURATION IN 288 EX 292 LOBE SEPERATION 107
CRANK(6223)FORGED STEEL
HEADS(3917215)67-68 cast head 101cc oval port. Have swirl pollished stainless steal racing valves, guideplates, screw in studs, springs to match cam,ported, flowed and mildly pollished
Motor is fresh and still needs alittle more parts. Have still in box vitor jr 454 intake(p#2904),MSD distributer(p#85551), pollished alluminum timing cver and fuel pump block off.
CARB(67202) 950 PROFORM RACING CARB-w/4 corner idle,srew in air bleeds and a 1or2' alluminum spacer
Been told motor should put out about 750hs just motor
Car can still be street legal as all headlights and taillights work and motor is still streetable
Will split up but this is a packaged deal, call for pricing
$6500.00 cash only no trades evenings 7-10 weekends all day (417)872-6137
Have more extras
You do not have the required permissions to view the files attached to this post.
Trevor
Re: 1981 Firebird drag car
Postby Trevor » Mon Aug 02, 2010 11:31 pm
You need to just put the engine back together and get this car back to the track!!
Stitches custom upholstery
207-7829
www.hubgarage.com/mygarage/redbeard
schafracer
Postby schafracer » Tue Aug 03, 2010 10:38 pm
Would love to get it back to the track. But going through a custody deal. Have to build something later.
