82 camaro
hotrodredneck
82 camaro
Postby hotrodredneck » Wed Sep 26, 2012 6:46 am
i have a 82 camaro drag car it is built as a bracket car it has run at mokan for years and ran at tulsa. its a great car just time for a change.fastest pass car has made is 12.37@114 with a 1.64 60 foot foot braking the car
CHASSIS
82 camaro
full hotchkis suspention front and rear
new struts in the front
10 bolt rear with spool and 4.10 gears
stock wheels in the front
aluminum wheels in the rear
275-60-15 bfg g/t drag radials in rear
solid motor and tranny mount
subframe conectors
MOTOR
4 bolt main 383
flat top forged piston
cast crank
5.7 x beam rods
fully balances
patriot parformance vortec head
2.02/1.60 ss valves
.550 lift springs
ported and polished
fel-pro 1266 port matched
lunati voodoo .489 lift cam
weliand stealth intake duel plan high rise
725 road demon carb
summit racing cdi ignition box
electric fuel pump
electric fan
TRANNY
th350 reverse patern valve body
built to TCI comp tranny specs
with all TCI hardend parts
3500 true foot brake stall
flashes to 4200
hurst quarter stick shifter
i am asking 5000.00 OBO i am open to trades at 6000.00 trade value the things i will trade for are dragsters turn key or good roller, tube chassis cars rollers, sport bikes or drag bikes. I will do part trades for coil overs or air shocks 12" travel or more,tube buggy chassis built ready to bolt parts on, 1 ton axles built,ford 9",rockwells.if you have something along these lines text me and let me know must have pics. you can text ONLY 479-531-5535 CAN EMAIL MORE PICS
You do not have the required permissions to view the files attached to this post.
hotrodredneck
Re: 82 camaro
Postby hotrodredneck » Sun Sep 30, 2012 1:54 pm
ttt would trade for a good pull rig
Users browsing this forum: Google [Bot] and 2 guests
