67 shortbed Big Block
brian
Postby brian » Fri Sep 28, 2012 1:37 pm
I have a 67 shortbed 2wd for sale. Has a brand new bed side on the passanger side. There is rust on the bottom of the front right fender where they all rust but I do have the patch piece for it. Has new carpet, new seals in the hole cab, new chrome instrument bezel, seat and door panels have been recovered in black denom. I have new door handles inside and out for it and new tail light and backup lenses. Would not take very long to have ready to paint. Inside has already been painted black. Has new aluminum radiator.
has a built 396/402 big block .
Forged TRW pistons
Truck rods with ARP bolts and have been resized
Forged steel crank turned .010/.010 with king pro series bearings
HV melling oil pump with ARP pump shaft
Comp cam double roller timing chain
Comp cams Xtreme energy cam 294/306 .588/.593 with matching comp springs, retainers and locks
heads are open chamber with new 2.19 and 1.88 valves and has comp stamp steel roller tip rockers
7qrt oil pan
SFI approved flexplate with ARP bolts
New dampner with ARP bolt
New single plane hurrican intake
New 4 corner idle 850 holley double pumper
new mini high torque starter
new head bolts
everything is aluminum- timing cover, timing indicater, fabricated valve covers, all brackets and pulleys and breather
new flex fan
new high volume short water pump
new alternator
msd plug wires
rotating assembly was balanced
has all new radiator hoses and heater hoses
new lex fan and spacer
Hooker competition heades with flowmasters
350th with race clutches and steels. B&M shift kit with extra deep chrome pan
mew u joints
new blower motor
new brake master cylinder
has B&M shifter
Brand new 5'' tach with shift light
Everything in and on this motor is new. I have over $5,000 in this motor . This thing sounds and runs awsome. Has only been drove up the road a cople times.
It is still a project and still needs some stuff done to it. $6500 or trade for camaro nova chevelle bass boat extended cab or 4 door chevy. call or text 417-699-3474
