383 SBC, 350 SBC,302 Ford NEW 6.5 GM heads FOR SALE !!!
Postby nickmcR » Tue Dec 04, 2012 3:34 pm
383 SBC
4-bolt block
Mahle 13.0:1 dome pistons
Mahle rings
4340 “H” beam rods
4340 crank
Howards custom ground solid roller cam
Crower lifters
487X heads, new stainless 2.02/1.60 valves, new valve springs, locks & retainers, screw in studs
Crane roller rockers
Holley strip dominator intake
Melling HV oil pump
Milodon 7qt oil pan
Fresh build, is on hotfire machine, can hear run
$ 2800.00 O.B.O.
(One time only price)
350 SBC
4-bolt block
.060 over hyper. flat tops pistons ( 9.5:1)
O.E. rods with new rod bolts
O.E. crank ( .010/.010)
882 heads with new valves(1.94/1.50), springs, retainers & locks
Elgin cam .465/.488, 290/300 dur
Professional products crosswind intake
Melling HV oil pump
Has oil pan, timing cover & valve covers
Fresh build, has had cam ran in on hotfire machine
$ 1400.00 O.B.O.
(one time only price)
302 Ford
.040 Hyper. Pistons
Moly rings
Clevite bearings
O.E. Roller cam
Double roller timing set
.010/.010 crank ( 2MAE)
Mellings oil pump
Truck heads with new valves, springs & locks
Fresh build
$ 850.00 O.B.O.
GM 6.5 Diesel heads
Center turbo, 90* intake bolt holes ( 92-99)
NEW valves, spring, retainers, locks & seals
$ 450.00 pr O.B.O.
351W ford Crank
351W mains
2.100 rod journals (sbc)
3.500 stroke
Bal. to 1967 grams
Nick McRoberts
