Register    Login    Forum    Search    FAQ
Board index » Classifieds » For Sale
Post new topic Reply to topic  [ 1 post ]
 Post subject: Parts For Sale
 Post Posted: Wed Dec 12, 2012 11:13 pm
1) BBC Dart Big M Block, 9.800 deck, Billet caps, Main Studs, O-ringed, 4.610 Bore, Needs resized, $900
2) Ohio BBC 4340 Crank, 4.250 stroke, .010 Rods, .010 Mains,just took out of motor with no problems $350
3) Ohio BBC 4340 Crank, 4.250 stroke, .020 Rods, .020 Mains,fresh from machine shop $350
4) BBC GRP Aluminum Rods 5300-STD, 6.385, 40 passes, $400
5) 10 used BBC JE Nitrous Pistons, #170717, 14.7 to 1, 4.600 bore, 4.250 stroke, 6.385 rod, 1.270 comp. height, $300
6) BBC Comp Cams Endure-X Roller Lifters, #899-16, .300 tall, offset, 1 lifter is broken, $100
7) BBC Howards Roller Lifters, .300 tall, $100
8) BBC Brodix Valve Covers, $100
9) BBC Hamburger oil pan, internal damage, $50
10) New Universal Engine Diaper $100
11) 1 set M/T 29.5 x 10.5 x15S slicks, 25 runs, $100
12) Pit Pal Slick Hangers, $50
13) New 94-02 Camaro Racecraft Rear deck filler piece $120
14) Bell Mag 4 open face helmet, small, $75
15) 8 used Ford 160 injectors, $350
16) BBC Ohio Extreme Duty I-Beam rods, 6 good ones, 6.385, Around $80 each for new ones, $100
17) BBC ATI Dampner, used, Internally balanced, $200
18) BBC GRP Aluminum Rods 5500 PRO, 6.385, 70 passes, some nicks from the broken lifter $250.00
For more info call 417-818-3147.
 Profile
Users browsing this forum: Google [Bot] and 2 guests
