Page 1 of 1
[ 1 post ] |
| Author |
Message |
alloutvega
Posted: Mon Feb 25, 2013 3:17 pm |
I have a C&S aerosol dominator set up for alcohol I believe it is around an 1150. $700
Manley 5.7 forged I-beam sbc rods with arp bolts used 175
Comp cams magnum roller tip self aligning rockers used set of 16 (I have 1.52, 1.6, or split ratio sets) 3/8 stud several sets available $100
BBC Eagle H-beam 6.385" rods with .060 forged speed pro pistons small domed used $300
Auburn Posi unit for 10 bolt 7.5" great shape $250
BBC Scat I beam Rods used $175
Scat 4340 forged crank sbc I believe it is for a 377 but will have to make sure std std used $400
Weld Prostars 15x14 5 on 5 6.5" backspacing $175
Holley 650 DP built by The Carb Shop in California gas carb $350
12 bolt out of 69 Chevelle with axles and 3.55 open diff FJ code $600
6.0 ls long blocks cores $500
Comp Cams 857-16 Pontiac tie bar Hydraulic roller rockers like new $275
Core Transmissions TH400, Th350, BOP, Powerglides, $100-200
New SRP 302/327 Hi dome forged pistons NIB part #147754 $400
Msd 7531 Digital 7 programmable plus box like new $500
2002 Corvette z06 engine 405hp 52,152mi long block $2500
Cummins 4bt diesel engines complete with all wiring accesories and transmission rotary pump, p pump or the newest version $3000
Mustang Chassis Dyno dont know much about it bought it from GA Tech University in like new condition $15,000
If it has a price then it is still available. Call or text 417-733-4021 if I dont answer leave amessage and I will get back to you. Ihave lots of other used parts as well if you need something not listed ask I may have it. Thanks
Shane
Page 1 of 1
[ 1 post ] |
Users browsing this forum: No registered users and 2 guests |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
