“Stock" suspension 10.5 car. AJE K-member, coilovers, new manual rack, caster/camber plates, Strange brakes all around, braced 8.8 with 35 spline Strange axles with 9 inch ends, 5/8 studs, Strange spool with 4.10 gears, Mike Duffy installed anti-roll bar, frame connectors and rear suspension. Battle Box floorpan bracket kit installed. Mini-tubbed, Current 8.50 cert mild steel 12 pt/funny car cage. Harwood 6" cowl hood and trunk lid, SOS wing, parachute and bracket, Markowitz air dam, Billet Spl Street Lites (15x10 & 15x4), new 28x11 M/T ET Streets & Goodyear fronts, MSD 7AL3 ignition, pnuematic starting line controller, Auto Meter tach & gages, EGT, air/fuel ratio, Hurst PG electric shifter. Wired for trans brake. All braided fuel system, sfi cell, Magna Fuel 500 pump with filter, Engineering Products regulator. New alumnium radiator with fan. Moroso oil accumulator with electric solenoid. B&M Trans cooler with braided lines, line loc. Kirkley seat with uphostery and current (in box) belts. Unassembled 496 BBC, with new Kooks headers (ceramic coated inside & out), Unassembled Powerglide with Ultrabell (New but out of cert) brake, cooler, electric shifter. and 5000-5500 8" Neal Chance bolt together convertor (fresh from their shop), Balanced motor has a forged Ohio Crank crankshaft,& 6.385" Ohio Crank rods, SRP pistons, Dart Pro 1 heads, Jessel Sportsman rockers and belt drive, MSD crank trigger pick up & distributor. Moroso vacumn pump, CNC ported Edlebrock Victor/1050 E-85 Dominator with PSI Dual Needle Valve/Dual Float Bowls. Motor is complete less pushrods., 24’ Vintage enclosed trailer to take it home in. In Wichita, KS $20,0000
