434 ALL ALUMINUM SBC RACE ENGINE 750 HP
kbhemi
Postby kbhemi » Mon Mar 25, 2013 11:01 am
OK - THIS IS SOMETHING YOU JUST DON'T SEE OFTEN FOR SALE - A 434 CUBIC INCH SMALL BLOCK CHEVY ALL ALUMINUM RACE ENGINE.
BLOCK IS A RODECK +.300 TALL DECK ALUMINUM WITH 4.155 BORE - THIS IS ONE LIGHTWEIGHT MOTOR - ROTATING ASSY - CALLIES 4.00 STROKE CRANK WITH A BIG BLOCK SNOUT, EAGLE 6.300 LONG H BEAM RODS, CLEVITE H SERIES ARCE BEARINGS, JE FLAT TOP PISTONS 13 TO 1 COMPRESSION, ATI BALANCER, INTERNALLY BALANCED. HAMBURGER STEEL RACE PAN WITH TRAP DOORS AND WINDAGE SCREEN 8 QT - MELLINGS HV PUMP WITH BOLT ON PICKUP, STEEL PUMP SHAFT. CAMSHAFT IS A LUNATI STEEL BILLET SOLID ROLLER.679 INTAKE LIFT AND .630 EXHUST LIFT, DURATION @ .050 IS 278 i AND 286 EX - PN 50175LUN GRIND NUM RRA-278-286-B, LOBE SEP 108, LOBE CL 104. HAS A $1000 JESEL BELT DRIVE SETUP AS WELL, CROWER LIFTERS, CRANE PUSHRODS, COMP CAMS STEEL MAGNUM - THE NEW STYLE - ROLLER ROCKERS AND A MOROSO STUD GIRDLE. HEADS ARE THE BRODIX SPEC HEADS - NUMBER SP-CH - THESE ARE 215 CC INTAKE RUNNERS, 2.08 INTAKE AND 1.60 EXHAST 23 DEGREE HEADS WITH STRAIGHT PLUGS AND 67 CC CHAMBERS. THEY HAVE TITANIUM RETAINERS, COMP CAMS SPRINGS AND LOCKS, BRODIX VALVES, GUIDEPLATES STD VALVE CENTERLINE, STD EXHAUST BOLT PATTERN - THESE ARE SOME BIG FLOWING HEADS! iNTAKE IS A DART - TALL DECK STD 4150 CARB FLANGE THAT HAS BEEN PORT MATCHED TO A FEL PRO 1206 GASKET AND MATCHES THE HEADS PERFECTLY. THIS MOTOR WAS JUST FRESHENED WITH NEW SPEED PRO FILE FIT RINGS, NEW SOLICOR HEAD GASKETS, NEW CLEVITE H BEARIGS, ONE PIECE SILICONE PAN GASKET ETC ETC. THIS MOTOR RAN 8.20S IN A 1900 POUND DRAGSTER ON A SINGLE 950 HOLLEY CARB AT 7200RPM - THATS 750 HP AND WITH THAT LIGHT OF A MOTOR IN YOUR CAR - WELL ITS GONNA GO FAST AND HOOK BETTER WITH THE REDUCED FRONT END WEIGHT AND REDUCED OVERALL WEIGHT OF THE CAR. i FRESHENED UP THIS MOTOR FOR A CUSTOMER AND HE'S DECIDED TO SELL IT AND RETIRE FROM RACING - AWESOME MOTOR. $8800 READY TO DROP IN TODAY. 316-761-7208
KEYWORDS - 400 350 355 383 406 410 427 454 412 SMALL BLOCK CHEVY DRAG RACE ENGINE PRO STREET PRO MOD
