'93 Mike Duffy Notch Roller in Wichita
hpdrifter
Postby hpdrifter » Sat Apr 27, 2013 10:00 am
New car - never run.
“Stock" suspension 10.5 car. AJE K-member, tube arms coil overs, new manual rack, caster/camber plates, Strange brakes all around, braced 8.8 with 35 spline Strange axles with 9 inch ends, 5/8 studs, Strange spool with 4.10 gears, Mike Duffy installed anti-roll bar, frame connectors and rear suspension & Mini-tubs. Battle Box upper control arm/ floor pan reinforcement bracket kit installed and braced to cage. Current 8.50 cert Mild steel 12 pt/funny car cage. Harwood 6" cowl hood and trunk lid, SOS wing, parachute and bracket, Markowitz air dam, Billet Spl Street Lites (15x10 & 15x4), new 28x11 M/T ET Streets & Goodyear fronts, MSD 7AL3 ignition, pnuematic starting line controller, Auto Meter tach & gages, EGT, air/fuel ratio, Hurst PG electric shifter. Wired for trans brake. All braided fuel system, sfi cell, Magna Fuel 500 pump with filter, Engineering Products regulator. New alumnium radiator with fan. Moroso oil accumulator with electric solenoid. B&M Trans cooler with braided lines, line loc. Kirkley seat with uphostery and current (in box) belts. $7500
496 BBC, Kooks headers, Powerglide w/Neal Chance convertor & brake & 24' Enclosed trailer also available with car or after car sells ..
email lizardofoz@att.net don't check for posts
hpdrifter
Re: '93 Mike Duffy Notch Roller in Wichita
Postby hpdrifter » Sun May 26, 2013 10:38 pm
S O L D
Users browsing this forum: Yahoo [Bot] and 1 guest
