351w "G" block and bryant sbf crank FS. And misc parts too
bluecoupe
Postby bluecoupe » Sun May 19, 2013 7:29 am
fresh 4.185 bore. 4 bolt mains on the centers. Cleveland mains. Short filled. ARP main studs. 9.2 deck. Has been o ringed. $800
Bryant 3.45 crank. Cleveland mains. 2.1 rods. Has some run time, but doesn't need any machining. $600 If you want the block and crank I will do $1200 on the pair.
"Yates" C3 heads with Ti valves. Also have springs that have 3 passes on them. The heads are unnassembled and I have flow sheets.
Hogan sheetmetal intake (9.2 deck matched to above heads) setup for 2 foggers. I have a twin 4500 top, twin 4150 top, and a single 4150 top for it. $1100
Comp .875 roller lifters and N20 cam. Offset intake and centered exhaust solid roller lifters. Low run time on cam and lifters. Built a new combo utilizing 55mm cam and .904 lifters. $300
.792i and .793e
@.050 279i and 286e
110 center line
I have pictures but no way of posting them. I will be happy to email or text them.
Located in springfield/ozark
Users browsing this forum: Bing [Bot] and 3 guests
