496 BBC, Power Glide & Kooks Headers
hpdrifter
Postby hpdrifter » Sun May 26, 2013 10:52 pm
Unassembled 496 BBC, with new Kooks headers (ceramic coated inside & out), Unassembled , Balanced motor has a forged Ohio Crank crankshaft,& 6.385" Ohio Crank rods, SRP pistons, Dart Pro 1 heads, Jessel Sportsman rockers and belt drive, MSD crank trigger pick up & distributor. Moroso vacumn pump, CNC ported Edlebrock Victor/1050 E-85 Dominator with PSI Dual Needle Valve/Dual Float Bowls. Motor is complete less pushrods. $6000
Unassembled 1.76:1 PowerGlide with Ultrabell (New but out of cert), TSR Pro Brake valve body, Deep cast BME pan, Hardened turbo input shaft, TCI aluminum drum, two new solenoids, all assembly parts. and 5000-5500 8" Neal Chance bolt together convertor (fresh from their shop). $1500
New Kooks headers for conventional head, 9.8 deck BBC in Fox with AJE K-member. Chrome ceramic coated inside & out by Performance Coatings +. EGT bung in #7. 4" x 10" extentions with cone mufflers. Includes AJE motor mounts. $850
In Wichita
Users browsing this forum: Bing [Bot], Google [Bot] and 3 guests
