BUILT 406 SBC-FS OR TRADE
63NOVA406
Postby 63NOVA406 » Sat Jun 22, 2013 9:08 pm
New built 406 small block chevy still on the stand. Never started. The engine is 13:1 compression with dome pistons so to run on pump gas the pistons would need changed, but this was built for street strip. Here are some of the parts: Internally balanced rotating assembly consisting of 4340 forged eagle crank and H beam rods with arp bolts. SRP forged 13:1 pistons, pro products damper and new high strength flex plate used for the balance as well. Block has been totally worked over with massaged oil passages and polished valley, align honed and studded 4 bolt billet main caps, and of course fresh .030" over bore and torque plate honed. Also was 90 degree zero decked. Professionally ported pro topline (RHS) heads 220 runners and 2.08 1.60 Brodix valves, crower heavy duty stainless roller rockers and comp solid roller lifters, comp pushrods, have to check on spring brand but they are good springs. Custom ground Howards billet solid roller nitrous cam 264/274@.050", .638/.635 on a 110 LSA. Rockers are 1.5/1.6 split so with the 1.6 on intake it is .680" lift. Edelbrock Victor Jr intake, drag race 8 qt baffled pan, mls gaskets,head studs. Engine was built and heads ported to give max benefits to nitrous efficiency so if you sprayed 200 you may get quite a bit more than that out of it. It has been estimated to be 650-700 horsepower on motor depending on fuel used and induction setup, etc. Everything has been balanced and blueprinted during assembly. Around $10k invested in parts and machine work, porting etc. May consider trading for atv's. I am looking for a 4 stroke dirtbike and a 4wd 4 wheeler, or possibly just 2- 4 wheel drive 4 wheelers. No junk-must run good and be dependable, 4 stroke only. $4000 if cash-trading is negotiable as this is worth a lot more than I am asking but if you have any of the items I am looking for shoot me an email with the info on them. Not interested in trading for anything else. Located outside of Joplin. Text, call or email. Working nights so please call between 1-3 or text any time 1pm to midnight. 417-8 five 0-56 seven 5. Thanks...PS-FOR PICS GO TO:
http://www.mokandragway.com/forum/viewt ... =4&t=53998
63NOVA406
Re: BUILT 406 SBC
Postby 63NOVA406 » Mon Jul 01, 2013 10:44 pm
Bump for price drop
63NOVA406
Re: BUILT 406 SBC
Postby 63NOVA406 » Sat Aug 10, 2013 2:12 pm
TTT
63NOVA406
Re: BUILT 406 SBC-FS OR TRADE
Postby 63NOVA406 » Mon Aug 19, 2013 2:09 pm
TTT for trade option added.
Users browsing this forum: 77440Wagon, Bing [Bot], Yahoo [Bot] and 1 guest
