6.0 GM, 351W Ford, 302 Ford, 6.5 GM heads, FOR SALE !!!!
nickmcR
Postby nickmcR » Thu Jul 18, 2013 10:18 pm
6.0 GM ( Non-DOD )
Cast Iron Block
Speed Pro .020 over HO pistons
Speed pro moly rings
Crank turned .010/.010 ( has been balanced)
O.E. bushed rods
Comp. Cams ( .571/.578) Hyd. roller cam
"853" Alum. heads ( have been ported, new valves, new springs, new retainers & locks)
FRESH BUILD[/b
[b]$ 2000.00 O.B.O.
351W Ford
.040 over Hyper. pistons
Moly rings
Elgin Hyd. flat tappet cam ( .512/.512, 228/228 @ .050 dur)
Double roller timing set
DOOE heads, with new valves & springs
Roller rockers
FRESH BUILD
$ 1000.00 O.B.O[/b
302 Ford
.040 Hyper. pistons
.010/.010 crank
Hyd. roller cam ( 302 HO cam)
New valves & locks
Melling oil pump
[b]FRESH BUILD
$ 800.00 O.B.O.
351W Ford Crank
4340
351W mains
2.100 rod journals ( SBC)
3.500 stroke
Bal. to 1967 grams
( NEW )
$ 300.00
GM 6.5 Diesel heads
Center Turbo, 90* intake bolt holes ( 92-99 )
ALL NEW CASTINGS
NEW valves, springs, retainers & locks
$ 450.00 pr O.B.O.
CALL Nick 1-417-860-0616
MACS PERFORMANCE POWERTRAIN
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
