500 HP BIG BLOCK CHEVY 461 CI $2500
kbhemi
Postby kbhemi » Mon Aug 26, 2013 3:06 pm
OK - SOMETHING YOU JUST DON'T SEE VERY OFTEN A PROFESSIONALLY BUILT 461 CI BIG BLOCK CHEVY - COMPLETE ENGINE INTAKE TO PAN - WITH ALL THE GOOD STUFF AND PUMP GAS FRIENDLY - THATS JUST BEEN FRESHENED UP WITH NEW RINGS, BEARINGS, GASKETS, CRANK GRIND AND CUSTOM ASSEMBLED BY A PRO - FOR ONLY $2500.
THIS MOTOR WILL MAKE 500 HP EASILY ON QUICK TRIP GAS. THIS IS A HYDRAULIC CAMMED MOTOR WITH .545 LIFT, THUNBPRINT TRUCK RODS, SPEED PRO FORGED 9 - 1 COMPRESSION RATIO PISTONS, GM 454 CAST STEEL CRANK, BALANCED ROTATING ASSEMBLY AND WAS JUST FRESHENED UP AT MY SHOP - NEW RINGS, BEARINGS, GASKETS, NEW LIFTERS, ETC ETC
THIS IS A NICE MOTOR
ENGINE SPECS/DETAILS -
BLOCK - GM 454 GEN IV TWO BOLT MAIN BORED +.030 TO 4.280, HAS DURABOND CAM BEARINGS.
CRANK - GM CAST STEEL .010 ON THE MAINS AND RODS TO THE LOW SIDE OF GM TOLERANCE, FRESH GRIND ON BOTH RODS AND MAINS.
BEARINGS ARE CLEVITE TRI BEARING HIGH PERFORMANCE. EXTERNAL BALANCED INCLUDES AFTERMARKET DEGREED BALANCER.
RODS - GM THUMBPRINT TRUCK RODS WITH ARP BOLTS 6.135 LENGTH - THATS A STD LENGTH ROD.
PISTONS - SPEED PRO FORGED MINI DOME 9-1 COMPRESSION RATIO OPEN CHAMBER WITH 1/16 X 1/16 X 3/16 SPEED PRO MOLY RINGS.
CAM - COMPETITION CAMS HYDRAULIC FLAT TAPPET, .545 INTAKE AND EXHAUST LIFT - DURATION @ .050 IS 246. A GREAT HOT ROD STREET N STRIP CAM.
LIFTERS - JOHNSON HI REV HYD - BRAND NEW.
TIMING SET - .250 DOUBLE ROLLER WITH BRASS THRUST WASHER.
OIL PUMP - MELLING M77 OIL PUMP WITH BOLT ON PICKUP.
OIL PAN - STD GM 5 QUART PAN, BOLT ON PICKUP.
HEADS - THE BEST GM OVAL PORT OPEN CHAMBER HEADS THE 781 - WITH ALL NEW STAINLESS VALVES 2.065 INTAKES AND 1.72 EXH - THESE WERE VALVE BOWL PORTED AND CLEANED UP - CROWER 10 DEGREE RETAINERS AND LOCKS - COMP CAMS EXHAUST VALVE ROTATOR ELIMINATORS, COMP CAMS 1.550 SPRINGS, ALUMINUM FULL ROLLER ROCKERS - NEW - 3/8 COMP GUIDE PLATES AND CV PRODUCT 3/8 PUSH RODS .080 CHROMEMOLY STEEL, MOROSO CHROME VALVE COVERS, MR GASKET MLS HEAD GASKETS - THESE ARE $100 GASKETS.
INTAKE - HOLLEY STRIP DOMINATOR SINGLE PLANE
THE BEST PARTS WERE USED - ITS EVEN GOT OIL AND FILTER INSTALLED AND PRE LUBED - THIS IS THE BEST ASSEMBLED PUMP GAS STREET N STRIP HOT ROD ENGINE YOU CAN BUY - BUT PRICED DIRT CHEAP TO SELL TODAY - $2500 FOR EVERYTHING - 316-761-7208
Users browsing this forum: Bing [Bot] and 1 guest
