drag race 750 hp + 468 BBC short block $2750
kbhemi
Postby kbhemi » Mon Aug 26, 2013 2:01 pm
THIS IS A PROFESSIONALLY BUILT 468 CUBIC INCH BBC DRAG RACE SHORT BLOCK - NO HEADS, INTAKE ETC. THIS MOTOR WILL MAKE 750 TO 850 HP DEPENDING ON YOUR HEADS. THIS IS A SOLID ROLLER MOTOR WITH .765 LIFT CAM, CROWER RODS, VENOLIA 13 - 1 COMPRESSION RATIO PISTONS, EAGLE 4340 STEEL CRANK, BALANCED AT SAUM ENGINEERING IN WICHITA KS. MOTOR WAS JUST FRESHENED UP AT MY SHOP - NEW RINGS, BEARINGS, GASKETS, NEW ROLLER CAM, ETC ETC
THIS IS A NEW MOTOR
ENGINE SPECS/DETAILS -
BLOCK - GM 454 GEN 5 FOUR BOLT MAIN BORED TO 4.310, HAS OIL RESTRICTORS, DURABOND CAM BEARINGS.
CRANK - EAGLE 4340 FORGED STEEL .020 ON THE MAINS AND STD ON THE RODS TO THE LOW SIDE OF GM TOLERANCE, FRESH GRIND ON BOTH RODS AND MAINS.
BEARINGS ARE SPEED PRO RACE BEARINGS THE CHAMFERED H SERIES ONES. EXTERNAL BALANCED INCLUDES BALANCER AND FLYWHEEL.
RODS - CROWER SPORTSMAN 6.385 LENGTH - THATS A +.250 LONG ROD, BUSHED PIN END WITH ARP BOLTS.
PISTONS - VENOLIA FORGED MAX DOME 13-1 COMPRESSION RATIO OPEN CHAMBER WITH 1/16 X 1/16 X 3/16 SPEED PRO MOLY RINGS.
CAM - CAM DYNAMICS STEEL BILLET ROLLER, .765 INTAKE LIFT .714 EXHAUST LIFT - DURATION @ .050 IS 282 / 292 - ON 110 LOBE CENTERS - VALVE LASH .030. THIS CAM IS BRAND NEW.
LIFTERS - CROWER ENDURO - BEST OF THE BEST.
TIMING SET - S.A. GEAR 78110T .250 DOUBLE ROLLER WITH TORRINGTON BEARINGS AND WITH A TORRINGTON BEARING CAM BUTTON.
OIL PUMP - 10778 SPECIAL RACE VERSION MELLING OIL PUMP WITH BEARINGS ON BOTH ENDS OF THE INTERNAL PUMP SHAFTS - HV AND WITH OTHER RACE FEATURES LIKE ADJ PRESSURE ETC ETC.
OIL PAN - HAMBURGER WITH CRANK SCRAPER, SCREEN, TRAP DOORS AND BAFFLES WITH A BOLT ON PICKUP. THE BEST PARTS WERE USED - THIS IS THE BEST ASSEMBLED RACE SHORT BLOCK MONEY CAN BUY - PRICED DIRT CHEAP TO SELL TODAY - $2750 FOR EVERYTHING - 316-761-7208
Users browsing this forum: Bing [Bot] and 2 guests
