Drag Buggy and Tilt Trailer
Matt82
Postby Matt82 » Mon Oct 07, 2013 1:47 pm
This is a Volkswagen dune buggy frame that has had the rear engine removed. It has a ford 8" rearend with 4.11 gears, minispool, moser axles. Has coilovers and ladder bars and wheelie bars. Has a sheetmetal floor, transmission tunnel and firewall. It is set up for a short shaft th350 transmission. Put the motor of your choice, has mounting tabs welded to the side to adapt nearly anything to. It originally had a SBC mounted and more recently I had an LS motor mounted, so its pretty universal. Comes with racing seat, fuel cell/tank, aluminum five star wheels and mickey thompson drag radials in the rear and just some stock steel wheels in the front (wheels on front in pics do not go with it) It has wheel adapters for the front to run either a ford car or chevy car pattern wheel, rear is ford car pattern. Has a quick detach steering wheel, brakes all around, master cylinder (not installed). Trailer is approx 5X10 single axle with expanded metal in the center. It was made to haul this buggy, it has lights, 2"ball, tilts for ease of loading and is lightweight. Have titles for both. $1500 O.B.O for all of it 417-683-826O
http://springfield.craigslist.org/cto/4086696518.html
Users browsing this forum: Google [Bot] and 2 guests
