6.0 GM engine, 400T transmission FOR SALE !!!!!
nickmcR
Postby nickmcR » Wed Oct 16, 2013 8:50 am
6.0 GM (NON-DOD, 2003 – 2007)
Cast Iron block
Speed pro .020 HO pistons
Speed pro Moly rings
Cranks turned .010/.010 ( has been balanced)
O.E. bushed rods
Comp. cams (.571/.578) Hyd. Roller
“853” heads ( have been ported, new valves, new springs, new retainers & locks)
Fresh build
$1900.00 O.B.O.
400T Transmission
JW Ultra bell
BTE transbrake
Steel hub
34 element sprag
Alto clutches
Roller bearing output
Kevlar band
Deep alum. Pan
FRESH BUILD
$ 1200.00 O.B.O.
3.0 Toyota engine
85-87
4 runner, pickup, T-100
FRESH BUILD
$800.00
GM 6.5 Diesel heads
Center turbo, 90* intake bolt holes ( 92-99)
ALL NEW CASTINGS
NEW valves, spring, retainers, locks & seals
$ 450.000 pr O.B.O.
351W ford Crank
4340
351W mains
2.100 rod journals (sbc)
3.500 stroke
Bal. to 1967 grams
(NEW)
$300.00
Call Nick
MACS PERFORMANCE POWERTRAIN
1-417-860-0616
Users browsing this forum: Yahoo [Bot] and 1 guest
