BBC, PowerGlide, Misc Parts & Tools make Offer in Wichita
hpdrifter
Postby hpdrifter » Sat Nov 02, 2013 12:01 pm
Everyone asks for my Bottom Dollar. Here they are. Won’t consider low ball offers. Every price shown is 20% to 25% under what I have in the item. (Might cut you a better deal on multiple parts.) All parts are FOB Wichita. Cash or Postal Money Order only. Not interested in trades.
NOTE: TRANSMISSION IS UNASSEMBLED. ASSEMBLY IS REQUIRED BUT YOU CAN CHECK EVERY PART YOURSELF. NO PICTURES. IF YOU KNOW WHAT IT IS, YOU KNOW WHAT IT LOOKS LIKE.
SOME NEW, SOME USED. LOOK AT THE PRICE TO SEE WHICH IS WHICH THIS IS OFF-ROAD RACING EQUIPMENT, SOLD AS IS
IF ITS STILL LISTED I STILL HAVE IT
Complete Oil System Deep Sump Oil Pan, New Mellings High Pressure/High Volume Oil Pump, Moroso Pickup, Surge Plate & Moroso Windage Tray, ARP Pump Stud $175 WON'T SEPARATE
Moroso 1 ½ Qt Oil Accumulator with new Electric Solenoid, Block Adapter and all Plumbing & wiring $275
1050 Dominator Carb ($750 Total WON'T SEPERATE)
Includes: 1050 HP Dominator / PSI Super Bowls (Fuel) Dual Needle/Dual Float (Won't lean out at top end) / Quick Fuel 1050 E85 Conv Kit installed with Baseline Jets & Bleeds (and all removed alcohol parts) Edlebrock 4150 to 4500 Adapter $45
Power Glide Transmission (Total $1500 UNASSEMBLED - WON'T SEPERATE)
Includes: Core / Neal Chance 8" Bolt Together 5000-5500 Conv Fresh from Chances shop for fresh up / Ultra Bell Bellhousing (New, but out of date) / TCI P/G Shift Lever / Hardened "Turbo Spline" Input Shaft / Two new Trans Brake Solenoids / New BTE Cast Deep P/G Pan / Steel High Gear Clutch Drum / Dual Ring Servo / Tailshaft Housing/ Locking Dipstick / Rebuild Kit -Seals, Gaskets, etc. / New TSR Trans Brake & Oil Volume Spacer Kit / Check Valve & Plumbing / OEM 1.76:1 Planetary Set / New ATI Shield Kit (out of date)
Kook's Custom Headers for BBC in Fox Body Mustang, Brand new. Chrome Ceramic Coated Inside & Out EGT Bung Brand New with Motor Mounts for AJE K-Member. 10" Collectors with Air/Fuel sensor bung and Vortec mufflers $825
New Chet Herbert Roller Cam (.685/.683 Lift. 290*/304* Dur 104* cc) & Chet Herbert Roller Lifters $400
Ignition & Electrical 57 New MSD RPM Pills 3K-9K, 1 Adjustable, 13 Retard & Storage Case ($285 WONT SEPERATE)
Odds & Ends
New EGT Sensor & Digital Read Out $110 Dendenbear Starting Line Controller $125 2 1/2# CO2 Bottle & Regulator with Bracket $100
Dominator Carb Bell $28
Pair New M/T Racing Tubes for 28/10.5 Tires $80
4500 NOS Solenoid Brackets $30 1 Gallon sfI Nitrous Enrichment Tank $70 Lots of AN hose fittings & Braided Hose (Inquire when you buy something else) New Moroso Crank Drive Mandrel $105
Tools & Equip
60 PSI Moroso Tire Gage w/Rubber $32
Quick Fuel E-85 Fuel Tester $12
hpdrifter
Re: BBC, PowerGlide, Misc Parts & Tools make Offer in Wich
Postby hpdrifter » Fri Nov 29, 2013 6:17 pm
Sold items removed and updated 11/29/2013
Users browsing this forum: Bing [Bot] and 1 guest
