killer gas powered air compresser 600 cash
MIKEGUY
Postby MIKEGUY » Mon Nov 04, 2013 6:12 pm
http://www.hyundaipower.ca/hcp9100.php
Features
Powerful 7HP gasoline motor
Recoil, electric and remote control starting
10' inflatable tire and wheel-barrow design increase portability
Large anti-sink plate and rugged wheels allow for maximum portability and safe operation
Intuitive colour-coded setup and control interface
Automatic low-oil shut down ensuring engine safety
Protected, precision-machined engine components
Rubber-mounted engine components reduce noise and vibration
Braided lines provide minimized risk of damage
Distributed exclusively in the United States by Cobalt Power.
Specifications
Engine: Hyundai HX208 7HP, 2950RPM
Starting method: Recoil and electric
Cooling system: Air cooled
Pump: 65 x 48 x 3 (bore x stroke x cylinders)
Running Time per tank: Up to 7 Hours
PAD @ 1090PSI: 18.5CFM
FAD @ 1090PSI: 13.7CFM
Cut in/out pressure: 9ba. or 87PSI / 8ba. Or 116PSI
Pump up time: 0-116PSI: 38.5 seconds
Recovery time: 87-116PSI: 8.5 seconds
Maximum PSI: 116PSI
Pump assembly: Precision aluminum
Fuel capacity: 1 Gal
Fuel type: Unleaded gasoline
Wear protection: Low-oil indicator and shutoff
Frame assembly: 32mm powder-coated steel
Weight: 264lbs
Operating noise level: 66dBa
Operating temperature range 0°-40°C (32 - 104 F)
Dimensions: 41x23x27"
Certifications: EPA
mine has 10 hours on it i will take 600 cash it was 1400 new
