Ford 393w stroker hydraulic roller coverted engine for sale
bearster18
Postby bearster18 » Wed Nov 06, 2013 10:06 am
have this ford 393 stroker long block up for sale. Was built fresh (new block) about 500 miles ago by a local guy here in mtn home.
Parts included are-
10.4 compression
RHS aluminum 180 cc heads, some slight intake port matching and bowl work
1.7 ratio roller aluminum stud mount rocker arms
Trickflow forged -18cc pistons/rings
manley forged connecting rods
SCAT steel stroker crankshaft
all clevite bearings
Trick flow stage 1 track heat EFI camshaft with trickflow valve springs
Harland sharp retro fit hydraulic roller lifters
comp cams hardened pushrods, double roller timing chain
High volume oil pump
comes with Summit racing harmonic balancer and ram flywheel matched to the external balance of the 351w based engine.
This engine is STRONG and torque filled-runs great. I have a video of it running in the truck it was in before I removed it too.
the oil pan is a double sump for fox body mustangs as well as the timing cover is for a mustang setup as well.
Only got about 500 miles total on it in about 18 months and its all gotta go. Financial issues are forcing me to get rid of my projects.
I'm asking $2500. Close to $5k + in this engine. Would be excellent for a truck or a car that just has overly excessive amounts of torque.
Not up for trades. Please text eight seven zero 421 3633 if interested. You come pick up.
98 mustang GT GONE--
97 cobra - blown, forged, and ready to go!!!! 458rwhp on stock block. Ready to crank up to some more boost and see what we can do. Now if only my engine builder would hurry up
Users browsing this forum: No registered users and 3 guests
