825 HP 477 BBC DART ALUMINUM HEADS $5000
kbhemi
Postby kbhemi » Tue Dec 03, 2013 11:30 am
825 HP 477 BBC ALUMINUM HEAD FULL ROLLER MOTOR COMPLETE ENGINE - $5000
THIS IS A PROFESSIONALLY BUILT 477 CUBIC INCH BBC DRAG RACE ENGINE - DART 320 ALUMINUM HEADS - JO MAR PRO SERIES ALUMINUM STUD GIRDLE, BRAND NEW COMP CAMS ULTRA GOLD ROLLER ROCKERS, COMP ELITE DUAL SPRING 1.640 DIA 265LB SEAT PRESSURE SPRINGS, 2.19 AND 1.88 STAINLESS VALVES, VALVE BOWL PORTED AND INTAKE PORTS GASKET MATCHED. DART CAST ALUMINUM TALL VALVE COVERS. EDELBROCK VICTOR 454-R DOMINATOR INTAKE FULLY RACE PORTED WITH A SUPER SUCKER SPACER PLATE AND 12 POINT BOLTS. THIS IS A COMP CAMS SOLID ROLLER MOTOR WITH .748 INTAKE AND .714 EXH LIFT, 286 DURATION @ .050 - 110 LOBE SEPARATION, LOBE CENTER IS 108 AND IS DEGREED IN AT 1 DEGREE ADVANCED. VALVE LASH IS .028/.030. THIS IS A SUPER GAS / SUPER COMP CAM AND COMP ROLLER LIFTERS CAM IS BRAND NEW LIFTERS DANG CLOSE TO NEW. BLOCK IS A GM 454 2 BOLT MAIN STD DECK HEIGHT WITH ARP STUDS AND IS BORED +.100, BLOCK IS HARD BLOCK FILLED TO THE BOTTOM OF THE WATER PUMP HOLES AND HAS ARP HEAD STUDS AND 12 POINT NUTS AS WELL - CYLINDER WALLS ARE PERFECT AS IS BORE. TIMING CHAIN IS A BRAND NEW SA GEAR .250 DOUBLE ROLLER WITH A TORRINGTON BEARING THRUST AND A CAM THRUST BUTTON. HD CHROME STEEL TIMING COVER AND TAB IS DEGREED IN TO TDC. EAGLE STD LENGTH 6.135 H BEAM RODS WITH ARP BOLTS - JE MAX DOME PISTONS WITH 1/16 X 1/16 X 3/16 - 13 - 1 COMPRESSION RATIO. SCAT 4340 4.00 STROKE .010/.010 FORGED STEEL CRANK, BALANCED AT SAUM ENGINEERING IN WICHITA KS. COMES WITH A SFI 8 INCH FLUID DAMPER AND AN SFI FLEXPLATE. MOTOR WAS JUST FRESHENED UP AT MY SHOP - NEW MOLY RINGS, CLEVITE H BEARINGS, FEL PRO AND MR GASKET GASKETS, MELLINGS HV77 OIL PUMP AND MOROSO PICKUP WITH A MOROSO DEEP SUMP 7 QT PAN.
THIS IS THE BEST ASSEMBLED RACE ENGINE YOU WILL FIND - PRICED DIRT CHEAP TO SELL TODAY - $5000 FOR EVERYTHING - 316-761-7208
PICS CAN BE SEEN HERE https://www.racingjunk.com/Drag-Racing/ ... NGINE.html
KEYWORDS 427 461 468 482 496 502 555 565
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 1 guest
