New 468 BBC
Chaps
New 468 BBC
Postby Chaps » Mon May 05, 2014 11:08 am
Everything is BRAND NEW. This includes EVERYTHING to assemble this motor, all machine work is done, all parts included.
Crank and cam are already installed.
14015445 4 bolt main block,
3987416 FORGED crank,
3872702 closed chambered heads,
KB257 12:1 dome pistons,
Eagle style H-beam rods with ARPs.
Brand new GM tin, valve covers, oil pan with dipstick, timing cover, never had oil in them. Screw in studs, rocker arms, new valves, HV oil pump/pick up/pump driveshaft, fuel pump pushrod, rod bearings, gasket set, rings, Crane lifter set, new head bolts, new pushrods, two harmonic balancers, .520 lift hydraulic flat tappet cam, heavy duty flex plate. Some condensation has gotten to the lifter valley, a few spots on the heads, and some of the rods, Minimal surface rust, cylinders and cranks are fine.
$3000 or partial trade with some cash. Looking for a good driver project, 60's something, no race cars, or try me, what do you have? Located near Springfield, MO. Call or text 417-849-0092
Users browsing this forum: Google [Bot] and 1 guest
