79 Camaro dragcar roller-reduced
OCTANEGEARHEAD
Postby OCTANEGEARHEAD » Tue Jun 03, 2014 9:34 pm
I have an 79 Camaro dragcar only(NO TITLE). This dragcar will make someone an great starter..the only thing you will need is an transmission. The details about the 79 dragcar is:
Prime job only was done last July.
This dragcar has been gutted with no interior...
-Dragcar details:
•new adjustable throttle linkage & adjustable throttle bracket
•b&m ratchet shifter with new shifter linkage
•6-point rollcage with driver side swing out roll bar with pin to get in easier
•racing seat with 5point seat belt harness •8gal fuel cell(full tank of 110 octane fuel)
•set up to run duel battery's that are relocated in the trunk with kill switch
•new Holley 12-150 electric fuel pump with two line fuel filters
•new master cylinder, new rear brake lines, new rear wheel cylinders, new brake shoes, drums, & brake hardware
•new rear axle wheel studs with new axle seals
•10bolt rearend with 4.88 Richmond gears
•rear adjustable air shocks
•cal-trac relocators with aftermarket racing leaf springs
•comp engineering sub frame connectors
•rear has slicks & front have skinnies with new rubber
•Driveshaft loop
•new chrome moly .83 driveshaft with th400 yoke
•tach, oil, water, & volt gauges, toggle switches & all electric wiring is already wired up with fuse box to be race ready.
•Pro Stock hood scoop with pins
I'm Joseph & u can contact me by:
Cell-call/text: (417) 770-2767
The new reduced asking price is $1750 OBO
Pictures on- http://springfield.craigslist.org/cto/4412520987.html
James Kelley
Re: 79 Camaro dragcar roller-reduced
Postby James Kelley » Fri Jun 06, 2014 9:55 pm
I want the shifter ??????? Trade you a pro stick for that one
James Kelley
Postby James Kelley » Sat Jun 07, 2014 7:03 pm
Or just buy it!!!
