Milodon 429-460 BBF oil pan/pickup - new
pontiacnut
Postby pontiacnut » Tue Aug 05, 2014 4:37 pm
Have a practically new Milodon oil pan and pickup for 429-460 BB Ford. Customer ordered the wrong pan/pickup for his application. Installed on engine and when dropped into his truck, wouldn't fit. Pan and pickup taken back off and shelved. Pan was on for the dyno run only. Pan part number 30929, and pickup part number 18398. Here's what Jegs says about this pan : These early chassis, pre 1974 front sump, low profile designs provide both increased oil capacity, as well as maximum available ground clearance. Increased oil capacity is an absolute requirement to handle the demands of higher RPM and increased horsepower. Suitable for heavy street and strip use. Oil control baffles 100% subdue any unwanted oil movement, which results in consistent oil pressure and increased horsepower output. Will fit all stock front sump chassis, all stock starters, all stock exhausts, and nearly all headers.
New Jegs price is 248.99 for the pan and 49.99 for the pickup. Wanting $277.00 for both.
low profile. 8 qt capacity + filter. 9 1/2" sump. Front sump design. Baffled.
Call with any questions or stop by our shop to see in person.
Hood Performance 417-255-9950
hoodperformance.net
Users browsing this forum: Bing [Bot] and 2 guests
