This weekend T&T
Re: This weekend T&T
Postby Larry Jr. » Wed Mar 11, 2009 8:04 pm
if it will run good on 30-33 degrees why screw with it?
Postby Bob » Wed Mar 11, 2009 8:07 pm
You dont know if its running up to its full potential unless you try it.
Postby Larry Jr. » Wed Mar 11, 2009 8:09 pm
and i will now that i got my new battery.....but i also dont want to put another flywheel in either.....i would give up a couple numbers just make sure it dont break teeth.....after 1 flywheel already this year.....and 4 flywheels last year....i aint pulling the tranny again LOL :lol:
Kimmis
Postby Kimmis » Wed Mar 11, 2009 8:19 pm
Larry Jr. wrote:it will run 5's easily....... we jetted it up and bumped up the timing to 33 degrees.and put a new battery in......... if it hooks good she will go 5's :thumbsup:
your only running 33degrees in a n/a alchohol motor? ;)
Postby 55promod » Wed Mar 11, 2009 8:49 pm
I ran 42 in my injected alky motor. I'd get the motor spinning before I flipped the ignition on.
Larry, I think you would pick up a bunch!
Postby Larry Jr. » Wed Mar 11, 2009 9:02 pm
nope just 30 degrees!!!!...i spin it and then turn it on, but for some reason it eats flywheels.....shannon beeler shimmed it last year and got it to not break teeth, and i got a start retard box on it too.....but my battery was shot also...i think it went bad last year,and just now replaced it.......i'll bump it to 36 and see what happens saturday
Postby sbmrx7 » Wed Mar 11, 2009 9:05 pm
Larry Jr. wrote:nope just 30 degrees!!!!...i spin it and then turn it on, but for some reason it eats flywheels.....shannon beeler shimmed it last year and got it to not break teeth, and i got a start retard box on it too.....but my battery was shot also...i think it went bad last year,and just now replaced it.......i'll bump it to 36 and see what happens saturday
Hold on :peel: :peel: :peel: :peel:
blowerbob
Postby blowerbob » Wed Mar 11, 2009 9:06 pm
Most ingnitions now days will pull timing out while cranking, but if you dont have one Keiths option works the best, just spin it a few times then hit the ing. should start with out kicking back!!!
Need to get something done!!!!!!!!!!!!!
Postby 55promod » Wed Mar 11, 2009 9:12 pm
One time I forgot to get it spinning and the starter kicked clear off of the car...it hit Mitch in the face....hopefully that explains some things
Postby sbmrx7 » Wed Mar 11, 2009 9:14 pm
55promod wrote:One time I forgot to get it spinning and the starter kicked clear off of the car...it hit Mitch in the face....hopefully that explains some things
:D :D :D :D :D :D :D :D :lol: :lol: :lol: :lol: :lol:
Users browsing this forum: No registered users and 0 guests
