Trans, carbs, LS, internals, wheels, rockers, 12 bolt, msd
alloutvega
Postby alloutvega » Mon Feb 25, 2013 3:17 pm
I have a C&S aerosol dominator set up for alcohol I believe it is around an 1150. $700
Manley 5.7 forged I-beam sbc rods with arp bolts used 175
Comp cams magnum roller tip self aligning rockers used set of 16 (I have 1.52, 1.6, or split ratio sets) 3/8 stud several sets available $100
BBC Eagle H-beam 6.385" rods with .060 forged speed pro pistons small domed used $300
Auburn Posi unit for 10 bolt 7.5" great shape $250
BBC Scat I beam Rods used $175
Scat 4340 forged crank sbc I believe it is for a 377 but will have to make sure std std used $400
Weld Prostars 15x14 5 on 5 6.5" backspacing $175
Holley 650 DP built by The Carb Shop in California gas carb $350
12 bolt out of 69 Chevelle with axles and 3.55 open diff FJ code $600
6.0 ls long blocks cores $500
Comp Cams 857-16 Pontiac tie bar Hydraulic roller rockers like new $275
Core Transmissions TH400, Th350, BOP, Powerglides, $100-200
New SRP 302/327 Hi dome forged pistons NIB part #147754 $400
Msd 7531 Digital 7 programmable plus box like new $500
2002 Corvette z06 engine 405hp 52,152mi long block $2500
Cummins 4bt diesel engines complete with all wiring accesories and transmission rotary pump, p pump or the newest version $3000
Mustang Chassis Dyno dont know much about it bought it from GA Tech University in like new condition $15,000
If it has a price then it is still available. Call or text 417-733-4021 if I dont answer leave amessage and I will get back to you. Ihave lots of other used parts as well if you need something not listed ask I may have it. Thanks
Shane
Users browsing this forum: No registered users and 4 guests
