moroso trick springs g body sold
500s10
Postby 500s10 » Fri Apr 19, 2013 4:54 pm
new still in box
Brand:Moroso
Manufacturer's Part Number:47135
Part Type:Racing Springs
Product Line:Moroso Trick Front Springs
Summit Racing Part Number:MOR-47135
UPC:084663471353
Spring Position:Front
Spring Type:Coil
Minimum Front-End Weight (lbs):1,720 lbs.
Maximum Front-End Weight (lbs):1,800 lbs.
Spring Rate (lbs/in):250 lbs./in.
For Street Use:No
Bushings Included:No
Progressive Rate Spring:No
Front Leaf Spring Bushings Included:No
Spring Finish:Black powdercoated
Quantity:Sold as a pair.
These tall, small wire diameter trick front coil springs, from Moroso, hold a great amount of stored energy for instant weight transfer. Each spring is computer designed for specific applications. They feature the correct rate for the particular application, and in most cases, can be installed with no modifications.
417-207-6481
Rumblerat
Re: moroso trick springs g body $100
Postby Rumblerat » Fri Apr 19, 2013 9:36 pm
Will they make me do crowd pleasin' wheelies like BOB does?????? :peel: :D
Nose-High FOREVER!!!!!
500s10
Postby 500s10 » Fri Apr 19, 2013 10:22 pm
Wheelie Bars not included :lol:
500s10
Postby 500s10 » Wed Apr 24, 2013 6:20 pm
Sold
Users browsing this forum: Bing [Bot] and 1 guest
