FOR SALE !!!! 6.0 GM Engine, New Alum. heads and More
nickmcR
Postby nickmcR » Thu Dec 05, 2013 9:01 pm
6.0 GM (non-DOD, 2003-2007)
Cast Iron block
Speed pro .020 HO pistons
Speed pro Moly rings
Crank Turned .010/.010 (has been Balanced)
O.E. Bushed rods
Comp. cams (.571/.578) Hyd. Roller cam
“853” heads( have been ported, new valves, new springs, new retainers & locks)
Mellings HV oil pump
FRESH BUILD
$ 2000.00
3.0 Toyota Engine
85-87
4 runner, pickup, T-100
FRESH BUILD
$ 700.00
GM 6.5 Diesel heads
Center Turbo, 90* intake bolt holes (92-99)
ALL NEW CASTINGS
New valves, springs, retainers & locks
$ 450.00 pr
351W Ford Crank
4340
351 W mains
2.100 rod journals ( SBC )
3.500 stroke
Bal. to 1967 grams
NEW
$300.00
SBC Pro-Comp Aluminum Heads
190 cc intake runners, 64cc chambers, straight plug
$ 450.00 pr ( NEW )
220 cc intake runners, 64 cc chambers, angle plug
$ 450.00 pr ( NEW )
SBC Double hump heads (492 castings)
2.02/1.60 Stainless valves
Massive port work
New valve springs ( .570 max, solid flat tappet, Hyd. Roller )
New valves
Fresh rebuild
$ 450.00 pr
SBC Flow-tech Block Hugger headers
( NEW )
$ 125.00
GM Performance parts SBC Roller Rockers
1.5
3/8 stud
NEW
$ 200.00
Manco single seat go cart
Comes with two engines ( neither one runs)
No clutch assem.
$ 100.00
CALL NICK AT 1-417-860-0616
nickmcR
Re: FOR SALE !!!! 6.0 GM Engine, New Alum. heads and More
Postby nickmcR » Mon Dec 23, 2013 7:17 am
6.0 Engine SOLD !!!!
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
