Precision PT106
bad355_67camaro
Precision PT106
Postby bad355_67camaro » Sun Dec 15, 2013 12:09 am
Changing turbos over the winter. It has a cast compressor wheel with a 4" v-band welded to the compressor discharge. It has the g-trim turbine wheel, with 1.0 exhaust housing. Both housings have been coated. I also have an 88mm reducer to bolt in that will make it legal to run in drag radial. $1600 shipped. Located in Carl Junction, MO. 417-499-three81zero
bad355_67camaro
Re: Precision PT106
Postby bad355_67camaro » Mon Feb 03, 2014 12:57 am
$1400 shipped
bad355_67camaro
Re: Precision PT106
Postby bad355_67camaro » Fri Feb 14, 2014 10:11 am
Sold!
Users browsing this forum: Yahoo [Bot] and 1 guest
