True Radial rules?
burns66
True Radial rules?
Postby burns66 » Thu Feb 19, 2009 1:41 pm
couldn't find them in the new rules section.
what are they, and what is the format for the class?
when will the class be run?
thanks
bjb
monstercarlo
Re: True Radial rules?
Postby monstercarlo » Thu Feb 19, 2009 1:49 pm
don't know my slef we are in same boat
offering to the god of speed we all have had a few.
DRL
Postby DRL » Thu Feb 19, 2009 4:20 pm
TRUERADIAL Heads Up Rules
Engine: any automotive engine permitted one power adder/single stage of nitrous, fogger ok/turbo any size/blower any size no boost controller/nitrous controllers/electronic traction control, or any other traction control; devices as deemed by track officials.
Frame & Suspension: cars must retain stock frame rails cars must have glass windows, trucks must have glass windows with the exception of the rear window may be lexan for roll bars to exit, with a 20lb weight penalty
Tire: No wider than a 275mm true radial tire with no less than a 250 tread wear rating, may be measured, no drag radials only two driven wheels allowed, 4x4's may be checked at the line for engaged 4x4
Miscellaneous: Cars will run a .400 pro tree, on a 1/8 mile. Cars must have full factory interiors, carpet, door panels and two front seats, (seat’s can be factory or aftermarket) rear seats are not mandatory. Cars can not have any fiberglass (except hood only). Cars must have working headlights, taillights, windshield wipers, and turn signal’s, (in their stock location)
Tech: Cars must have coolant overflow tank, and secured battery mounts. Cars must be able to pass safety tech, NO Exceptions.
69 Chevelle on the way, BB Powered--- Boosted---
burns66
Postby burns66 » Thu Feb 19, 2009 6:35 pm
can stock frame rails be notched?
it also looks like ladder bars are okay..?
where did you get those set of rules. i can't find them anywhere on the website.
bjb
monstercarlo
Postby monstercarlo » Fri Feb 20, 2009 9:22 am
the ruls use to be posted on the old bord a better qustion is doe's the class still exist or has it just ben renamed can't find it on sec.so ????????????answers any one pleas,&,thankyou
Postby 55promod » Fri Feb 20, 2009 9:59 am
I'll have an answer on all of the above in the next couple of days. Lots of stuff on my plate right now
monstercarlo
Postby monstercarlo » Fri Feb 20, 2009 10:26 am
thanksknow about lot going on take yout time
DRL
Postby DRL » Fri Feb 20, 2009 9:55 pm
HEY BJB I THINK SOMEBODY POOFED THE RULES !!!! THEY WAS WITH THE REST OF THE HEADS UP CLASS RULE'S!! JEFF's CAR UP AND GOING YET!! SO BE PREPARED FOR THIS TOPIC TO BE POOFED LOL !!!!!!
monstercarlo
Postby monstercarlo » Tue Feb 24, 2009 11:18 am
lets keep this topic in mind still need to know whats up :?: :?: :?:
Postby 55promod » Tue Feb 24, 2009 11:42 am
No, I'm not poofing it. Just don't have an answer.....yet
Users browsing this forum: Bing [Bot] and 12 guests
