Any plans on making the track shutdown area longer?
WHALE DRIVER
Location: Last Pontiac Standing. Free the Whales or the trainer gets it !
Re: Any plans on making the track shutdown area longer?
Postby WHALE DRIVER » Thu Feb 19, 2009 10:20 pm
Maybe a lot more hay? some sand? A big bungee?
1.39 60' 6.59@104
463"OF REAL PONTIAC POWER
ARE YOU PREDATOR OR PREY?
monstercarlo
Postby monstercarlo » Fri Feb 20, 2009 10:39 am
we all know going faster is better bou it's a dubbel edge sord maybe insted of making shut down longer , one should up graid the braking system with the motor . :oops: just my thought not wonting to step on any feelings
offering to the god of speed we all have had a few.
crankitup
Postby crankitup » Fri Feb 20, 2009 1:44 pm
93_SVT_FREAK, that looks like a good idea to give us a few extra feet to slow it down. It would keep the cost down too.
93_SVT_FREAK wrote:
Jamond Haug wrote:The shutdown will not be lengthened due to the huge drop off at the end.
We applied for some of the stimulus $$ for a shutdown bridge to nowhere.....
How about a wide right turn at the very end? :lol: :burnout:
JamesN
Postby JamesN » Fri Feb 20, 2009 2:31 pm
that would be a very nice addition.
Little Pierce
Postby Little Pierce » Sun Feb 22, 2009 9:03 pm
Scott Palmer has been how fast? and he stops....
JamesN
Postby JamesN » Mon Feb 23, 2009 12:45 am
Little Pierce wrote:Scott Palmer has been how fast? and he stops....
1/8 vs 1/4.
chute vs no chute.
Palmer has alot more distance to slow that mph down. Plus he is a pro. Certainly not everyone coming to the track is as seasoned or prepared as palmer.
AlteredMopar
Postby AlteredMopar » Mon Feb 23, 2009 5:42 pm
Actually Scott was over 240mph through the 1/8 and his chute failed to open one night. He used all of the far end and one pair of shorts. He was able to do it, but does not recommend doing that on a regular basis. I have run it out the big end before with no time, and my car will be around 160mph in a 1/4. You don't want to wait even a little to hit the brakes on my car. Through the 1/8 I almost don't have to use the brakes, if I do I can make the first return. I could probably pull my chute and slow down lots quicker in the 1/4, but then I'd have to climb out store the laundry before I went back to the pits. I would like to go 1/4 too, but I'm happy with 1/8. I could consider 1000ft. ;) though.
Wheels Up!
PB
Do the voices in my head bother you too?
Postby 55promod » Mon Feb 23, 2009 5:58 pm
AlteredMopar wrote: but then I'd have to climb out store the laundry before I went back to the pits
By laundry do you mean your shorts or something else ?
turbo69camaro
Postby turbo69camaro » Mon Feb 23, 2009 6:27 pm
I had no chute one time at a 168 in the 1/4 my front end just touched the hay bails lol
.........Confidence is the feeling you have when you don't fully understand the situation........
AlteredMopar
Postby AlteredMopar » Mon Feb 23, 2009 7:08 pm
yes :D :o :o :shock: :shock:
Wheels Up!
PB
Users browsing this forum: Baidu [Spider] and 1 guest
