for sale
chevyracer2004
for sale
Postby chevyracer2004 » Sun May 09, 2010 6:54 pm
1991 v8 s10 short bed done right and very sharp , older 350 4 bolt main 40 over 11 to 1 srp flat top pistons gm pink rods moroso high volume oil pump lunati voodoo hydraulic flat-tapet cam and lifters 233/241-504/525 has pete jackson noisy gear drive set of patriot performance heads 2.02/1.60 stainless valves 3/8 studs & guide plates screw in 3/8 studs 64 cc chambers, with 185cc intake runners set of harland sharp 1.5 aluminum roller rockers vortech aluminum intake with 650 demon gas carb with elc choke acel hei style dist with acel 8.8 mm race wires headman shorty headers with all new 3" aluminum pipe from headers into 40 series flow master with turn downs at the rear end griffin aluminum radiator with dual elc cooling fans moroso v8 mounts gm 7.5 rear end with alburn posi unit with new richmond 373 gears with a built 350 turbo with b-m 1800 to 2000 stall ,all new bumpers,grill ,turn signals.headlight asb,after market tail lights, paint is one year old pretty purel ecent hugger orange nice gray interior with bench seat b-m mega shifter 5" moster tach with exteral shift light cd player and speakers grant gt sterring wheel and rolls on a set of weld pro stars 15x8 with new tires on the back and front set of 15x3/1/2 weld front runners with new front runner tires on the truck and im shure i have left alot out ? this truck has ben well put together and sounds great call 417-350-8361
You do not have the required permissions to view the files attached to this post.
chevyracer2004
Re: for sale
Postby chevyracer2004 » Thu May 13, 2010 9:24 pm
sold
Users browsing this forum: Bing [Bot] and 2 guests
