Many Race parts for sale
spray power
Postby spray power » Fri Nov 23, 2012 9:05 pm
Callies BBC 4.750" stroke std/std used - 850.00
Olliver MAX steel BBC new in the box 6.700" rods - 1,000.00
ATI 8 inch internal balance balancer for BBC - 200.00
Compo deal on Callies crank, Olliver MAX rods and ATI balancer - 2,000.00
Brodix 12 degree used intake - 225.00
Brodix 18 degree used intake with lots of porting and efi bungs and rails - 600.00
Brodix speced 50mm roller cam bearing BBC nitrous roller cam - 100.00
Strange Double adjustable 5" stroke GT front struts, used for only 11 passes - 1,400.00
Waterman 120" new cable drive (cable only) - 125.00
Grant's Heavy duty 120" cable drive used (cable only) - 225.00
Moroso Blue bullit BBC oil pump used - 75.00
Moroso BBC Crank trigger and pick-up - 75.00 SOLD
NX 10 lb. Super Hi Flow nitrous bottles (have about 13 left) used most are still full and all have gages - 150.00 each / will make deal if buying more than one!! Only have 8 left
Comp Cams 948 Trible valve springs / 3 used sets (all sets have less than 70 passes on them) - 75.00 a set
M/T used 29.5" x 10.5" Stiff wall slicks / have 3 sets ( all set's have less than 20 passes per set) - 100.00 per set HAVE 1 SET left
Diamount Custom BBC piston (9) new in the box / 4.610" bore, 12 heads, 4.500" stroke, 6.700" rods (contact for more info) - 500.00
Harwood firber glass Fox body deck lit used - 100.00 SOLD
BTE 1.80 Powerglide, Pro Brake, 10 clutch, vasco imput, Deadenbear case, deep pan etc. - 2,500.00 SOLD
Schoneck Composits Fox Body Carbon Glass doors for use with roll up windows(also have new wheather striping for the window channel, outside felts, outside upper molding and inside/outside door handles all new for the doors) - 1,500.00 SOLD
MSD 7531 box (used) with wiring harness and a MSD 8261 HVC coil (used) - 700.00 for the pair
1989 Fox Coupe mustang body complete less hood and gas tank (has 4 cly. auto in it that doesn't run) great for making a race car out off!! - 1,000.00
NEW Schoneck Composits Carbon Fiber 4 inch cowl hood for 87-93 fox body - 1,000.00
NEW Glasstek fox body fiber glass doors with Harwood lexan (also new) - 650.00
Weld Polished Magnums 15" x 14" wheels - 2 passes on them, 6 inch back space, 5 on 4.750 bolt pattern, drilled for 16 wheel schrews per side (will do some trading on some 15 x 12 bead lock wheels with a 3.500 back space and 5 on 4.750 pattern)- 650.00
The above WELD wheels with M/T 29.5" x 10.5" W tires also with 2 passes on them - wheels and tires compo - 900.00
FAST XFI 2.0 system, internal data logging, main harness, power adder harnes, cam and crank sensor harness, wide band O2 sensor, MSD dist set up for cam sensor(chevy) with cap and MSD wires, air temp-water temp-map sensors. Will remove from car after it's sold - 2,100.00
Billet aluminum duel nitrous bottle holder, holds both 10 and 15 lb. bottles - 125.00
Skinny Kid Race Cars Ladder Link 4 link brackets, body and rear end housing with doublers. These are can be used as Ladder bar or 4 link brackets, new - 375.00
Stock OEM 87-93 LX nose, no tears - 75.00
8 1/2 inch turbo spline N/A convertor, was behind a 632 inch with a glide and went some 5.30's on motor. That's all I know about convertor other than it was done by Southern Transmission. - 250.00
Complete all aluminum 632" BBC, Brodix block, Lunati steel crank, ATI aluminum balancer, GRP Pro Mod Rods, Wiesco coated piston, Comp Cams belt drive, Pro Pan's aluminum oil pan with Steff oil heater and dieper, Comp Roller cam bearing custom nitrous roller cam, .904 Comp oil feed lifters, Trend 1/2 inch push rods, Brodix 12 degree Man Eater heads, Tit. intake and exhaust valves, Tit. retainers and locks, Trible Comp Valve springs, T & D Rockers, sheet metal valve covers, Ported Edelbrock Big Victor cast intake with three dry NX nitrous systems (third never been used), EFI inector bungs, custom fuel rails with 83 lbs. injectors, Custom blended spacer, FAST 2,005 cfm TB, MSD front drive dist., MSD wires, MSD crank trigger, Aermotive crank drive mandrill, BTE sfi flywheel, Air pan with Lexan intake scoop, Nitrous dist. block with braided insulated lines going to all three kits, Aeromotive belt drive fuel pump with -10 braided line going to fuel rails, Car Tech efi regulator. Motor never hurt and well taken care of. Has been 5.18 on motor in a nitrous car at 2,815 lbs. and 4.79 on a single .026 fogger kit and low 4.70's on two kits. This is a complete engine less front engine plate. Have tunes ups for EFI system that will go with engine along with all paper work with engine. - 21,500.00
PTC 9 1/2 Nitrous convertor for above engine also for sale, turbo spline. Will not sell unless engine sells.... 625.00
Package deal on 632" engine, PTC convertor, and FAST XFI system - 23,000.00
1988 Fox body Coupe mustang shell - roof, quarters, front frame rails, strut towers and part of the floor board and that's about it. - 300.00
A set of used .904" non off set BBC solid roller lifters - 100.00
A used set of GRP 6.700" bbc aluminum rods, around 85 passes - 50.00
A used set of Bill Miller 6.600" bbc aluminum rods, 65 passes - 50.00
A used billet aluminum BBC oil pump, brand un-know - 50.00
Prices are OBO on most items..
Thanks for looking....
Auston
spray power
Re: Many Race parts for sale
Postby spray power » Tue Mar 05, 2013 8:23 pm
Made some up dates to the list....
Thanks
bigblock55
Postby bigblock55 » Tue Mar 05, 2013 8:30 pm
Could the diamond pistons be re-cut for std 23 deg heads?
spray power
Postby spray power » Wed Mar 06, 2013 9:45 am
bigblock55 wrote:Could the diamond pistons be re-cut for std 23 deg heads?
I would say yes, but not knowing the hole set up it's a little hard to say...
orangebird2
Postby orangebird2 » Wed Mar 06, 2013 7:48 pm
What size cables 3/8 or? Looking for a Enderly style 3 bolt mount on 3/8 hex drive. Also would u sep msd box, if so what would u take for the 7531?
spray power
Postby spray power » Wed Mar 06, 2013 9:57 pm
orangebird2 wrote:What size cables 3/8 or? Looking for a Enderly style 3 bolt mount on 3/8 hex drive. Also would u sep msd box, if so what would u take for the 7531?
The new Water man I think is 5/16" and the used Grant cable is 3/8", both have hex nuts on the ends. The back of the oil pump had a 3 bolt plate on it that went to the threaded part of the cable and the fuel pump mount/surport had the same threaded part on it.
orangebird2
Postby orangebird2 » Thu Mar 07, 2013 8:59 pm
Ill let you know my oil pump should be here by next week so when it gets here ill measure to see if I can use it. Thanks Mike
orangebird2
Postby orangebird2 » Fri Mar 22, 2013 9:37 pm
Could you send me your contact info or call me? My number is 417-399-4933 thanks Mike
Jamond Haug
Postby Jamond Haug » Thu Mar 28, 2013 8:33 am
Interested in the balancer
Please call or text
Jamond
417.840.5035
A closed mouth gathers no feet
Users browsing this forum: Bing [Bot] and 2 guests
