Page 1 of 1
Nitrous Express NX Digital Maximizer Controller - $350
Posted: Wed Mar 24, 2010 1:35 pm
by Badass90lx
The Nitrous Express Maximizer, the controller that will revolutionize the progressive nitrous controller market. This unit uses a Palm PDA to upload and display the Maximizer information. This is the ONLY unit on the market with a built in RPM activated window switch with gear counting capability, the first with a TPS switch to activate or de-activate the nitrous system.
The Maximizer also has a delay on, or delay off feature, will ramp up or down for turbo cars, and you can change the ramp parameters for each gear. Finally, the unit will piggyback on your O2’s to allow the monitoring of the engine air/fuel ratios. By setting the high/low parameters the Maximizer will read, and monitor the air/fuel ratio. This allows you to disable the nitrous at any pre-set ratio.
PDA device not included.
Brand: Nitrous Express
Product: Digital Maximizer
Part #: NX 15963-PDA
Condition: NEW
MSRP: $849 (save lots$$)
Applications: Universal, for Nitrous Express systems
it's NOT ok to contact this poster with services or other commercial interests
Re: Nitrous Express NX Digital Maximizer Controller - $350
Posted: Fri Mar 26, 2010 8:29 am
by Badass90lx
Also have a set of Moser C Clip 9300 these are for a ford 8.8 rear end Stock axles $125.00 also have a AOD REBUILD KIT $90.00 ALSO HAVE A WIRING HARNESS FOR A 1987-1993 MUSTANG THIS IS FROM THE COMPUTER ON 90.00 THERE IS NO COMPUTER WITH THIS :peel: :peel: :peel: :peel: :peel: :peel: :peel:
Posted: Tue Mar 30, 2010 10:58 am
by Badass90lx
250 and it's u'rs :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Posted: Fri Apr 02, 2010 3:47 pm
by Badass90lx
SOLD SOLD YAHOOOOOOOOOOOOOO :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
