Motoped Survival (Pit Bike?)
LS1T240Z
Postby LS1T240Z » Mon Jun 12, 2017 7:03 am
I have had this for about year and have driven it a few times around the neighborhood. It was brand new when I bought it. ITs still perfect with nothing wrong with it. 49cc $2000 obo Pictures of actual bike available. I could not get them to load on here.
FEATURES
Patented Jackshaft Pedal Drive System
Forged Aluminum Crank Arms
DNM Adjustable Front and Rear Suspension (6″ active travel)
4130 Chromoly Single Tube Frame
Double Heat Treated 6061 Aluminum Swing Arm
22″ by 6″ Aluminum Rear Rack (30 lbs. max load)
Hayes 9″ Hydraulic Front and Rear Disc Brakes
Durable 24″ and 26″ wheels with a wider, thicker, dual wall design
Rotopax 1 Gallon Storage Tanks (2)
Custom Motoped Performace Rear Hub
SPECS
Engine Displacement – 49cc / 125cc
Max Horsepower – 49cc – 2.0 HP @ 7500 RPM / 125cc – 7.78 @ 7500 RPM
Max Torque – 49cc – 1.70 ft-lbs @ 5500 RPM / 125cc – 6 ft-lbs @ 5000 RPM
Starter Type – 49cc – Electric / 125cc – Electric & Kickstart
Front Suspension – 3-way Adjustable DNM Forks (6″ travel or optional 8″ travel)
Rear Suspension – 2-Way Adjustable DNM Shock
Brakes – Hayes Prime DH Hydraulic 4 Piston Calipers with 224mm (9″) Rotors
Rim Size – Alex Rims 26″ Front and 24″ Rear
Tire Size – Front: 26 x 2.6 Rear: 24 x 3
Wheelbase – 52″
Seat Height – 32″ (Standard – 6″ travel) 34″ (Optional – 8″ travel)
Max Speed – 24 MPH
Unit Weight – 132 lbs.
