355 SB chevy for sale SOLD
Ron
Postby Ron » Sun Oct 15, 2017 9:18 pm
.030 over 350 4 bolt main 1 piece seal
Forged steel crank 1 piece seal Internally balanced
Manley "I" beam rods W/ARP bolts
JE/SRP flat top pistons 10.3-1 Pump gas!
Custom grind solid flat tappet cam
AFR CNC ported 195cc heads
Edelbrock Vic. Jr intake manifold. port matched to the heads
Comp Cam Magnum 1.6-1 ratio rockers with stud girdle
Pro systems 750 holley carb
MSD billet distributor and plug wires
edelbrock Alum water pump (Long)
SFI flex plate
mini starter motor
recent leakdown done a SHO-ME speed 2% leakdown max on all cylinders
Compression test all cylinders within 5lbs compression to each other
Professionally built with dyno sheets for engine and engine in car
Engine is at Sho-Me Speed
$1500.obo
Call/Leave Message 417-725-0138
Users browsing this forum: No registered users and 5 guests
