565 ci BBC
ratwagon
565 ci BBC
Postby ratwagon » Tue Jan 22, 2013 1:14 pm
Merlin III Cast Iron Block
Brodix Aluminum Heads 2 Extra Big Brodie
Ohio Crankshaft Rotating Assembly
4340 Non twist Steel Crank
4340 H Beam Rods
13-1 Comp JE Pistons
Comp Roller Cam 800 Lift
Comp Roller Lifters
Comp Steel Roller Rocker Arms
Stud Girdle
Moroso Billet Aluminum Oil Pump
Cloyes Adj Timing Cover w. Roller Cam Button
Cloyes True Roller Timing Chain Set
Edlebrock Super Vic 2927 Intake
MSD Dist w/ Morose Ultra 40 Wires
CSR Electric Water Pump
Cat Fluid Dampner
Aluminum H V H Super Sucker Carb Spacer
1150 Dominator Carb
Racing Plugs
Gear Reduction High torque Starter
Estimate HP between 800-900
Engine has 30 - 1/8 mile passes since new & 15 passes since refreshed
Engine ran 6.3 1/8 mile in 3600 lb car & 5.8 in 1/8 mile w/200 shot NOS
$7800 or best offer (may take partial trade on gun)
Contact Russell 561-716-3579
You do not have the required permissions to view the files attached to this post.
Just Jim
Re: 565 ci BBC
Postby Just Jim » Tue Jan 22, 2013 8:09 pm
:thumbsup: .....awesome looking beast there... :peel:
slightly burned out, but still smokin'......
Users browsing this forum: No registered users and 0 guests
